F-Body International
12-10-2017, 09:43 PM
I have a complete setup that I put together over the course of a year. Only reason I have it for sale is that I ran into some expensive repairs on my '98 Trans Am (daily driver) and I'm planning on going back to school. My setup is basically my own vision of how our Pontiac's should've received EFI. All parts are American made. The TBI is a Rochester (just like a Quadrajet) and the distributor is factory Pontiac design. I personally have yet to see this combination GM parts run on a Poncho. You will need to install a fuel system on your vehicle but this gets you a true GM TBI and computer controlled ignition for a great price!
-Complete Megasquirt Carb-To-EFI Kit (brand new)
-Innovate LC-2 Wideband (brand new)
-'81 Turbo 301 distributor
-Complete rebuild by PY forum member SunTuned
-Dissambled, cleaned, regreased, shimmed, and reassembled.
-This is a '81 only 7-wire HEI that's designed for computer control.
-Works with 301-455 engines
-Rochester TBI from a 454 built by SPR Performance
-GM and aftermarket carburetor intake adapter base included.
-Injectors cleaned
-All hardware replace with stainless
-IAC and TPS replaced with NOS Delco
-Throttle bores opened to 54mm
-Throttle blades installed to match 54mm bore
-Throttle shaft shaved for increased air flow
-Injector pod spacer increased air flow and better fuel atomization
-Fuel pressure regulator block-off plate installed so an external unit can be used.
$1200
https://static1.pt-content.com/images/pt/2017/12/36046843624_676a027f46_z-1.jpg (https://flic.kr/p/WVkuKS)SPR Performance 454 TBI (https://flic.kr/p/WVkuKS) by Jonathon Randolph (https://www.flickr.com/photos/156619454@N04/), on Flickr
https://static1.pt-content.com/images/pt/2017/12/23903541778_967ca1420a_z-1.jpg (https://flic.kr/p/CqgUbE)Computer controlled Pontiac HEI (https://flic.kr/p/CqgUbE) by Jonathon Randolph (https://www.flickr.com/photos/156619454@N04/), on Flickr
https://static1.pt-content.com/images/pt/2017/12/23903541768_d507f22cc5_z-1.jpg (https://flic.kr/p/CqgUbu)Computer controlled Pontiac HEI (https://flic.kr/p/CqgUbu) by Jonathon Randolph (https://www.flickr.com/photos/156619454@N04/), on Flickr
https://static1.pt-content.com/images/pt/2017/12/38976708351_022a477051_z-1.jpg (https://flic.kr/p/22oePsX)Megasquirt Kit (https://flic.kr/p/22oePsX) by Jonathon Randolph (https://www.flickr.com/photos/156619454@N04/), on Flickr
-Injectors cleaned
$1200
