View Full Version : 02 sensor wiring hanging down low under car, looking for routing ideas
DT69Cam
12-10-2017, 09:53 AM
Hey guys, my 02 sensor wiring hangs awful low, looking for ideas on how to mount them up and out of the way using the plastic push in plug that is attached to the connector. Thx
12sec ss
12-11-2017, 06:23 PM
you can make some brackets off the trans with a hole for that push pin plug, but most will use a zip tie or 2 to get them out of the way
DT69Cam
12-12-2017, 01:16 PM
That's exactly what I did, thank you.
tmcmillan5
12-12-2017, 02:23 PM
Yeah mine too on the passenger side. Can the extension cable be cut shorter and then be re-pinned ?
Thanks, Tony
DT69Cam
12-12-2017, 04:32 PM
Thanks, Tony
You know, I'm not sure, I think the o2 sensors are very sensitive. I fabbed up some "L" brackets using 20 gauge sheet metal. I secured them to the transmission. Perfect.
badazz81z28
12-13-2017, 08:01 PM
I suggest cutting and re-pinning. That's what I did.
