yody
09-20-2004, 07:46 PM
I finally got my clutch linkage in, it conists of 1/2" tubing with 3/8 nuts tig welded on both ends and 3/8 heim joints in both ends, that is for the long top bar, i also duplicated the stock bend in it so it clears the hole in the firewall. On the bottom bar i just cut the stock end off if it and tig'd on a nut and added a heim joint, i kept the stock adjustable push rod on the other end.
I lubed up the ball joints on the z bar and installed everthing. I am using a Mcleod Borg+Beck Twin Disc street Clutch on a 454, I am using a Mceod Bellhousing, and a Lakewood Clutch Fork and Adjustable Pivot ball.
When installing the clutch/bellhousing i had to run the pivot ball real far down towards the bellhousing to create the proper leverage, Its kinda hard to tell but it looks like the clutch fork is correclty pointing towards the back of the block when the throwout bearing is just touching the clutch.
I have checked over and over but can't really find anything wrong with the setup, but for some reason the clutch is Super Stiff!!! I called the guy I got the clutch from (slightly used, only a few passes at the drag strip) and he said the clutch when in his car was effortless, I then called "Red" at Mcleod and he said the same thing, that these clutches are supposed to be pretty soft!
Any ideas here? i could really use some help, i don't want this stiff clutch! thanks!
