View Full Version : Holley 302-2 Pan hitting LS2 rod bolt
AU Doc
12-09-2017, 11:06 AM
I’m mocking up my Holley 302-2 pan to check for clearances with my rotating assembly and with the pan on the block without the gasket the front rod bolt just barely hits the pan. Is this normal? I think it will clear once I add the gasket, but that’s a heck of a tight fit!!!
oleyeller
12-09-2017, 11:57 AM
146822 When I installed mine, I rotated it by hand and the rod bolt gouged a chunk out of the pan. It looked to me, like there may have been a shift during the casting process, the dish in the bottom of the pan seemed to be in the wrong place to avoid the rod bolt. I just started grinding, and ended up smoothing out the entire inside of the pan. Just got rid of all the casting roughness, and removed more material where the rod bolt hit.
AU Doc
12-09-2017, 12:30 PM
Hmmm.... did it hit with the gasket installed?
It looks like it could be as little as the nut being turned in just the wrong direction. Like you’re saying, it could be just the casting roughness making the difference.
dhutton
12-09-2017, 01:16 PM
Is it a stroker? You need the 302-3 pan for a stroker....
Don
AU Doc
12-09-2017, 01:50 PM
No, it’s not a stroker. Just a stock LS2
kochevy67
12-09-2017, 07:14 PM
I am definitely not liking this news, I just bought a pan and am about to put it on.
AU Doc
12-09-2017, 08:06 PM
I found one other post on the interwebs saying the 302-2 hits the rod bolt without the gasket. I’m planning to flow up with Holley on Monday.
andrewb70
12-09-2017, 08:24 PM
But who uses the pan without the gasket?
AU Doc
12-10-2017, 06:05 AM
Haha! Very true. Though I’m still surprised they manufacture the thing with the clearances that tight.
andrewb70
12-10-2017, 06:09 AM
Because when using that pan in an A body it needs to be as slim as possible in the front. Pretty sure a stock F-body pan hits without a gasket too. It too is really slim in the front.
AU Doc
12-11-2017, 12:18 PM
Holley tech support confirmed what is being said here. The pans are built to be a TIGHT fit. They said they've never heard of anyone having an issue with them once the gasket is installed, but they also would not commit to whether it's common/expected for the rod bolt to hit the pan on some applications before the gasket is installed.
That said, the gasket on this thing is around .100"-.125", which gives me a .050" to play with.
DT69Cam
12-11-2017, 05:08 PM
Which gasket are you using ?/ I reused the new stock LS3 gasket on mine.
AU Doc
12-11-2017, 06:34 PM
I’m using a GM gasket. 12612350 is the part number, I believe.
AU Doc
12-16-2017, 10:07 PM
Well here’s an update. I decided to pull the pan again and do a little grinding.
When I took out the gasket and put the pan back on to find where it was hitting (a little red trans gel on the rod bolts), the rod bolt didn’t hit the pan. WTH!?!? After some fiddling I finally figured out the back of the pan (the bell end) has to be misaligned off to one side to make the bolt hit. The first time I mocked up everything I didn’t use any pan bolts. With everything lined up correctly, there is no interference. So the pan went right back on with no grinding.
andrewb70
12-17-2017, 06:50 AM
Some engineer thought of that ;-)
AU Doc
12-17-2017, 07:12 AM
Engineers.... what are you going to do? :-)
It’s pretty impressive how little the pan had to be canted for it to cause a clearance problem.
