View Full Version : Powermaster starters 9500 9528 9612, ARP BBC head bolts
chuckd71
12-09-2017, 06:50 AM
Putting everything I have left into one post. [/FONT][/COLOR]
https://www.flickr.com/gp/21527394@N06/w94n3L
Prices as listed, will sell all three starters for $425 shipped, which is basically like getting one free at Summit's prices. Starters are new except the Quartermaster one was mocked up and the bolts were lost. Plenty of pics. If you wanted everything in the post I'd do $510 shipped, or if you have a FedEx or UPS account and wanted to send me shipping label I'd take $475.[/FONT][/COLOR]
]Powermaster 9500 $160[/COLOR]
[Small block Chevy V8 with 168T flywheel[/COLOR]
Infi-clock system 146813146812146811
200 ft-lbs of torque at peak HP
Clears most oil pans and headers
[COLO00]Operating range: -40C to 150C [/COLOR]
4.4:1 gear reduction
1.4kW (1.9HP)
Recommended for up to 18:1 compression
8.5 lbs (starter only)
No heat soak problems
APPLICATIONS INCLUDE
2.8L 173CID V6
3.1L 189CID V6
4.1L 250CID I6
4.3L 262CID V6
4.4L 267CID V8
4.8L 292CID I6
5.0L 305CID V8
5.0L 307CID V8
5.7L 350CID V8
6.5L 396CID V8
6.6L 400CID V8
6.6L 402CID V8
6.7L 409CID V8
7.0L 427CID V8
7.4L 454CID V8
8.1L 496CID V8
Powermaster 9528 $160
Missing the mounting bolts, has grease smudge stains from hands (but no actual grease) on it from mock up
XS Torque Starter - Quarter Master Bellhousing
https://www.summitracing.com/parts/pwm-9528
Powermaster 9612 $160
This lightweight high-torque gear reduction starter clears all headers and oil pans where original equipment starters won't. The Mastertorque Starter is an excellent choice for mild race or high performance street applications where heat soak is the main concern. Features 4.4:1 gear reduction ratio and 180 ft. lbs. of torque. Also features an adjustable mounting block. Fits Chevy applications.
168 Tooth Flywheel
Adjustable mounting block
4.4:1 Gear Reduction Ratio
Recommended for 12:1 compression
Weighs 11 pounds
ARP 1353703 $90
High Performance Series Cylinder Head Bolts, 12-Point Style, For Select Chevrolet Big Block Applications 135-3703
https://www.summitracing.com/parts/arp-135-3703
