View Full Version : Chevelle Build Restart...where do i go from here?
cypher
11-28-2017, 03:35 PM
So eleven or twelve years ago i got this bright idea, i want to get another chevelle ( sold the original 72 ss i had while i was in college, i know, stupid me for selling it) but would love to put one of the new LS chevy motors in it so i would FI. I started lots of research and decided that a pro touring car was what i wanted, even though back then i had no idea thats what it was called. About 6 to 8 months later found a car that i could afford.... which i wont get into its problems here, and a wrecked 02 T/A about 5 miles down the road from my house and bought it and the project was on like Donkey Kong. Fast forward over 10 years; growing kids, lose of job, finding new job, moving , the list goes on and on and i have stalled out and nearly going in reverse project.... BUT i want to change that and start moving forward again.. But where to start.
Things i have:
1) i have the car i want..but the car body, frame, suspension, etc needs a metric ton to get "complete".
2) i have a 58k mile LS1 and an unknown T56 condition sitting in front of the car
3) I have brand new front suspension pieces...tubular UCA & LCA,afx spindles from scandc, vette brakes calipers from a friend donating to the build all sitting in a box inside the car.
4) I have Hellwig FrameFX bought and sitting in box on floor
The car/project needs everything else.
no interior, no fuel system at all, no other braking system minus front calipers, no wiring other than dash/column (which needs changed)
Now to the real part of this post... where and what to start on. I feel like over the last 10 years this project went from a somewhat uncommon at the time LS swap to now a complete car overhaul; meanwhile i havent gotten anything but quarter panels and trunk replaced and bought a few random pieces as they were on sale over the years. Its taking way longer than i thought when i started so my end goal/wants seems to be moving as the times change. I have zero technical or physical issues with doing this build as im very mechanically minded and was a part time mechanic in my earlier years but the project just never seems to move forward. Like any good project you need to have a plan of attack so you stay on coarse and for the most part, its still the same. Ive contemplated upgrading some aspects of the car to newer versions of what was available to me back 10 years ago (ls1 to ls3, t56 to t56 magnum, etc) but all of those would just be back tracking and im afraid that will even further delay the build.
1) Is it worth back tracking to newer things to make the end result of the car what i want now compared to back then or just start with what i currently have to motivate forward and replace down the road as needed?
2) The good running low mileage engine i bought 10 years ago has sat for the last 6 years. All intake and exhaust ports has been fully sealed, but should i worry about a partial tear down before installing?
3) Is the frameFX kit even worth welding on the frame?
4) Fuel system: If your building everything from scratch, would you go with the slightly less expensive tanksinc tank and pump or upgrade to the ricks restomod tank and gen 5 camaro pump assembly? Return or returnless lines? Old style corvette filter\regulator or other.
If you were in my shoes, where would you go/start? I think if i dont start soon, ill never get off the ground. Sorry for such a scatter brained post, but i guess thats what i get when i do this just after getting off work before heading home.
raustinss
11-28-2017, 05:12 PM
id say get it together even without interior and such ...engine trans installed and running ,see if that creates a desire to continue . If not at least the running driveable car can be sold to someone else
rallystyle
11-28-2017, 10:12 PM
the ls1 t56 is a good setup. i would run it. the hellwig kit is a good idea also. if you didnt have the ls1 mounted yet i would say get the holley kit. it will make everything drop in and the exhaust would not be a problem. the crossmember would not work with the hellwig kit. the ricks tank restomod tank is nice. you can use the oe fuel hose the the the front. also you will not have fuel problems around curves. i would get a aaw wire kit. its nice to start with new stuff that has not been hacked over the years and you can run it to hide it and make it clean. get it running first then you will want to work on it more. the first time you turn the key it will make it all worth it.
1965_SS
12-04-2017, 07:23 AM
You say your old car was a 72' Chevelle. Did you buy another Chevelle? and an 02' T/A? What year is the new Chevelle?
cypher
12-04-2017, 05:16 PM
Originally had a 72 SS back in the day... bought the new car which is a 71 plain jane car about 10 years ago. The ls1 came from an 02 trans am automatic car. I found a T56 for a couple hundred bucks but i have no earthly idea if its good, It was sitting on a concrete pad under a tarp when i bought it. I was looking at rebuild kits for this thing, it might almost be cheaper to buy a brand new t56 magnum than the possible fixes for ls1 t56.
I do have the holley mounts and headers purchased but they did not have the crossmember when i bought it all. That gets me into wondering about the hellwig kit, Im thinking i need it in place before i get engine completely setup so to build the trans crossmember.
For fuel system: Is a ricks resto tank worth the near double price compared to tanks inc setup? Return or returnless for the lines? Its a stock LS1 now but i have sourced 243 heads and will put a bigger cam, One of these days i imagine either turbo or LS3 or some mixtures of the two. I would prefer something that is capable of future upgrades.
lawrenq
12-09-2017, 12:46 PM
I'm in the same boat as you except that I'm going on 3 yrs with my build in my Chevelle, I've already done the metal work, new suspension and all new wiring. I have an 06 ls2 and t56 that I bought a while back but never ran and like you I was considering upgrading.
I've come come to the conclusion that the longer that I stall on this project, the more things I'd want to change. My goal this year is to just get the car running with what I have so that I don't lose interest.
