View Full Version : E85 Carbs
KB Camaro
11-27-2017, 12:53 PM
Does anyone have experience running one? Any opinions, my biggest concern is that it would not be a "flexfuel" car that can adjust timing if you get a tank of E50 during the winter months when the blend is slightly different. Anyone have any other concerns/thoughts?
lolo3198
01-02-2019, 06:08 AM
interested if you have answer ;)
Buryingthesun
01-22-2019, 04:31 PM
Are you looking at Quick-Fuel? Just remember you'll require 25%-30% more flow, so larger fuel lines and a healthy fuel pump will be required. You'll also want to have fuel lines and a tank that's suitable for E85
here's some more info, I looked into it when building my 408ci LS but decided to keep it to 93 pump gas
https://www.e85carbs.com/tips.htm
MonzaRacer
06-02-2019, 06:56 PM
Biggest issue is the E85 fuel minimum spec is 51% ethanol rather than old spec of 70%. Now best way would be to find an adjustable FI set up. always wondered how well a FiTech would handle different ethanol content.
F-Body International
04-10-2020, 04:55 AM
If anyone looks into this, Innovate makes a combined “ethanol content” and “wideband gauge”.
An E85 carb can be tuned very well with this type of tool.
https://www.innovatemotorsports.com/products/ecf1.php
