View Full Version : LS3 water pump inlet/outlet
DT69Cam
11-24-2017, 03:25 PM
Does the water pumps on the GM crate LS3 engines have an Inlet and an Outlet for the heater hoses ??? The 2 hose connections are side by side next to each other.
dhutton
11-24-2017, 03:36 PM
Yes. The smaller one is the out side. The larger one is the return.
Don
DT69Cam
11-25-2017, 05:04 AM
Don
Thx Don
DT69Cam
11-26-2017, 06:39 AM
Also, as you mentioned, the smaller fitting is the outlet side, this would be considered the (Intake) as per the directions/diagram from Vintage Air correct?
dhutton
11-26-2017, 06:42 AM
Yep.
Don
DT69Cam
11-26-2017, 07:15 AM
Yep.
Don
Thanks Don!!
