View Full Version : Garage clean out-SBC, BBC, Camaro, Olds, Pontiac parts (long list)
bergers59
11-21-2017, 06:04 PM
Up for sale is a bunch of miscellaneous parts for sale left over from projects and parts cars. Mostly original parts, however I have a few nice aftermarket parts listed also. If you need more pictures or the pics aren't listed, message me and I'll be sure to get some. The parts listed are as follows:
-1st gen camaro
-2nd gen camaro/firebird steering column(with key)(60)
-3rd gen corvette sbc headers, may fit other applications (100)
-sbc valve covers(40)
-1990s SS truck big block valve covers(60)
-Chrome BBC valve covers (30)
-k&n style air filter(20)
-holly 650cfm carb(almost new)(350)
-rally nova/camaro wheel caps(60 for set)
-66/67 gto/tempest hubcaps(40 set)
-miscellaneous gm hubcaps/trim rings(5 each)
-5 quadrajet carbs(40 each)
-cragar wheel center caps(some brand new)(5-10 each)
- 2 two barrel intakes(10 each)
-multiple pairs of sbc exhaust manifolds(10 each pair)
-set of 15x7 JJ rally wheels
-b&m torque converter,car never ran with part on it, part number 20416 (170)
-Date coded drum to drum 67 Camaro rear end 3.55 Posi, differential is cracked between spider gears.
-66/67 GTO front bumper. Has dings but is a good core and is fairly straight
-66 389/421 092 heads 70cc. Correct heads for a 4 barrel 66 GTO
- Rally II wheels with trim rings(looking for center caps, we have them somewhere)
- date coded 66 4 barrel 326/389/421 intake
- 67 GTO center console door. Original wood is in great shape, however there is a chunk of the chrome/metal missing on the side. Would need to be welded or silver soldered then re-chromed.
- high comp 70-71 B.O.P W30/400/455 starter, date coded late 1969
-71 firebird/GTO 37 amp alternator
-78 firebird a/c or defrost 61 amp alternator
- 71/72 B.O.P 400/455 with a/c or HD cooling alternator, also believe it is coded for big block chevy from same years
-64 tempest rear
-64 gto/lemans dash pad
-64 gto doors(need patches)
-64 gto bumper brackets
-64 gto inner wheel wells
-64 gto taillights/gas door
-64 tempest gas door
232_ray
11-21-2017, 06:46 PM
What's the Numbers on the Muncie bellhousing?? Also is the 3.55 rear end a 10 or 12 bolt?? Where are u located??
bergers59
11-22-2017, 02:56 PM
Bellhousing already sold, 3.55 rear is a 10 bolt. Berkeley Heights NJ
Zl1427
11-22-2017, 04:18 PM
What's the store on that Inner Wheel well ?
bergers59
11-22-2017, 10:04 PM
store? also 64 gto or 67/68 camaro?
Johnzee67ls3
11-22-2017, 10:34 PM
Do you have a first gen drag link bar?
bergers59
11-22-2017, 10:47 PM
Yes I do
