View Full Version : do I need subframe connectors running 350hp/400tq?
David in NC
11-17-2017, 06:47 AM
67 Camaro coupe
RamJet 350 (350hp/400tq)
front tubular control arms, rear swaybar
stock frame
drives tight
should I have subframe connectors or not necessary with <400hp?
77thor
11-17-2017, 08:48 AM
Yes.
BMR Sales
11-17-2017, 10:28 AM
Yes!
chpr1972
01-06-2018, 07:59 AM
They tell you yes, but no reason! Horse power and torque has little to do with pro-touring in a sense. What you are trying to eliminate is body twist. Zero Structure rigidity is what you are trying to do. Remember the lifted tire coming out of a curve?
F-Body International
01-06-2018, 02:21 PM
A better investment is solid body mounts. Subframe connectors can be installed later.
yep !! to subframe connectors..... all first gens need them, and all second gens also, first gens had narrow bias ply tires, even if you still run a 7 or 8 inch rim now, the radial tires you run have more grip than GM ever imagined and the body flops and twist because of this
