View Full Version : Holley Alternator pigtail needed ???
DT69Cam
11-11-2017, 11:18 AM
I'm using the GMPP harness with my crate LS3 and the Holley Acc drive kit. The Holley kit comes with an Alternator pigtail. This pigtail has a resistor installed in it. Do I need to use this pigtail or can I just plug my GMPP harness Alternator plug in the Alternator ?? I believe the resistor is needed if NO charge light is used. My GMPP harness may have the resistor installed already, not sure? Thx!!
andrewb70
11-12-2017, 06:18 AM
Don't use the Holley pigtail. Just plug in the connector on the GMPP harness...
DT69Cam
11-12-2017, 09:59 AM
Thank you Andrew!!
12sec ss
11-12-2017, 10:54 AM
The resistor is used if you don’t want to use pcm control on the alternator. It’s 470ohm iirc and wired to the ignition. I would use the gmpp harness and no resistor. Holley brackets use regular truck alternators FYI.
DT69Cam
11-12-2017, 01:26 PM
Thanks!
