View Full Version : I want to autocross with new engine
brycedrue
11-09-2017, 10:28 PM
I have 250 miles on my fresh rebuild. Still using break-in oil. Is it too soon to autocross it this weekend? If so, how many miles should I rack up before it's good to go?
GoodysGotaCuda
11-10-2017, 04:13 AM
After a couple of heat cycles and a few full load passes in between, I'd be good to go.
nokones
11-10-2017, 05:34 AM
Just make sure that it doesn't overheat. Autocrossing is not that much of a difference than some in-town traffic driving from stoplights to stoplights.
SSLOW6.0
11-10-2017, 06:18 AM
Send it.
Once the rings are seated, you're not going to hurt anything. (short of hydraulic flat tappet cams which do require an extended break in time) I think once you establish you have good oil pressure, hammer it, seat the rings and let it eat until it blows up.
It seems all the engines I baby on start up, have issues. Where as the ones I thrash seem to last forever.
brycedrue
11-10-2017, 07:00 AM
As soon as the engine started I put some spirited passes on it (LS swap)
SSLOW6.0
11-10-2017, 07:05 AM
I'd say you're fine then. If you want, change your oil, cut open the filter to verity it's happy then race this weekend.
