View Full Version : Custom made A/C hose ??
DT69Cam
11-05-2017, 02:00 PM
Anyone know of a good source for custom A/C hose made to your specs ?? Thx
Bad Bowtie
11-05-2017, 03:12 PM
Look into EZ Clip by Eaton / Aeroquip... Vintage Air sells these kits to make up your own lines without crimping. Very easy to use and saves a lot of time and makes it easy to "clock" your fittings. They are a little pricey but I think worth the money for time saving and a lot less aggravation.
BB
GoodysGotaCuda
11-05-2017, 05:18 PM
I was able to borrow a crimp tool and DIY it, it's not too bad of a process if you can get ahold of a crimper.
csouth
11-05-2017, 06:23 PM
If you have a Pirtek near you, I would buy a kit from an AC vendor and make them myself. Clock them, mark, then take them in for crimping.
badazz81z28
11-05-2017, 06:31 PM
What Di you need? I can make you one. I have the proper crimper and fittings.
DT69Cam
11-06-2017, 01:18 PM
I only need an 11 1/2 inch piece overall (end of straight fitting to end of 90 fitting) I was going to have a shop custom bend some tube because I was afraid the hose would not bend in a tight radius before kinking. 1 straight female o-ring #10, and 1 90* female o-ring #10.
DT69Cam
11-06-2017, 05:10 PM
I just double checked the measurement. Its actually 8 inches long overall.
LemonTwisted
11-07-2017, 09:02 AM
If you go with the EZ-Clip hose and ends check out HoseWarehouse.com (http://hosewarehouse.com/specialty/Field-Specific-EZ-Clip-A-C-Hose-and-Fittings). Their prices are much cheaper than the A/C specialty places.
csouth
11-07-2017, 10:12 AM
So what you actually need is a custom fitting not hose?
DT69Cam
11-07-2017, 12:59 PM
No, No, one end of the hose will have a straight fitting on it, the other end of the hose will have a 90 degree fitting on it. Anyway, thanks for the replies guys. I found a local place that made it up for me.
OLDFLM
11-07-2017, 02:02 PM
My local NAPA does it... maybe check locally?
badazz81z28
11-13-2017, 06:31 PM
I sent you a PM. I have a hose, just need the length and I can put the fitting on it.
TheJDMan
11-15-2017, 08:16 PM
I used to work for NAPA and most stores have the equipment to make up custom AC hoses.
Zspoiler
11-16-2017, 02:06 PM
Have you tried your local "AC" shop.
