nevasuma
10-24-2017, 04:26 AM
Here is what I have, ls2 out of a 2006* in my 78 trans am with t56. I am running a qft hr-780-vs carb, with holley sniper gas tank with fuel pump in tank. I have a automotive dual stage fuel pump regulator knocking the pressure first done to 12 psi and then down to 6.5 psi for the carb. My ignition is msd 6014 box.* Timing starting at 15 and going to 28 all in by 1500 rpm.*
here is my problem. The car will not run right.**I have the idle circuit good with afr in the 13's. But anything after 1/3 throttle under load the car breaks up, bogs, backfires and sometimes stalls. Seems like it is going lean.* Not sure if it's carb tuning or fuel starvation.*
Thanks for any advice or help!!
