View Full Version : E-Brake Cable For Baer IronSport Brakes
AU Doc
10-13-2017, 05:07 AM
Can anyone recommend an e-brake cable to use with Baer IronSport brakes? I just swapped a Ford 9" into my camaro and used the IronSport disc brakes. The instructions are pretty vague about how to select an e-brake cable.
The IronSport caliper uses a ball end cable, cables can be purchased from Lokar (General fit cable), or Control Cables.
Does anyone have an suggestions?
dhutton
10-13-2017, 05:16 AM
Lokar. They have a kit you cut to length. You will also need the Corvette clevis kit.
http://lokar.com/product-pgs/ebrake-cables-conn-cables/ebrake-cable-pgs/ebrake-cables.html
http://lokar.com/product-pgs/ebrake-cables-conn-cables/ebrake-cable-pgs/rearbrake-clevis-kits.html
Don
AU Doc
10-13-2017, 09:20 AM
Thanks for the links!
I checked with Lokar, and they recommended the EC-81FU. I've got one on order, and I'll let everyone know how it works.
dhutton
10-13-2017, 12:41 PM
Did you order the clevismkit too? You’re going to need it....
Don
AU Doc
10-13-2017, 12:55 PM
No. What's the clevis kit for?
EDIT: Just to clarify, the clevis is usually used at the e-brake actuator, correct? the IronSport calipers use a ball-end cable to actuate the e-brake. Here's a pic showing the e-brake actuator on the caliper.
145171
dhutton
10-13-2017, 06:34 PM
Never mind that looks like some kind of Cadillac caliper knockoff which is quite different from the other Baer rear disc brakes that use a drum style parking brake. My mistake.
Don
toddz69
10-14-2017, 09:01 PM
The Ironsport calipers are late-model Mustang calipers.
Todd Z.
AU Doc
10-16-2017, 05:11 AM
Don
Gotcha! Thanks for help!
Todd Z.
You are correct. SN95 I believe. We'll see how they do.
chuckd71
10-16-2017, 01:29 PM
Just sort of fyi, my lokar kit came with a couple clevises, might be worth verifying the kit contents before ordering extra stuff (not that you need to, but other people reading this might).
dhutton
10-16-2017, 02:16 PM
Damn. I have purchased several Lokar cables and they have never included clevis parts. Must be buying a different kit.
Don
