View Full Version : LS swap 69 Camaro w a 1990 (metric) PS Box
DT69Cam
10-12-2017, 01:39 PM
How did you guys run your power steering hoses from the pump ?? I'm using the complete Holley LS swap kit. Just looking for some ideas. Thx!
andrewb70
10-12-2017, 01:53 PM
I convert the steering box and pump to AN-6 fittings then go to my local hydraulic store and have them make custom hoses for me. Tell them what you are doing and a good shop can help. They generally call AN fittings JIC in the industrial world...
DT69Cam
10-12-2017, 02:06 PM
Thank you Andrew
andrewb70
10-13-2017, 06:34 AM
You're welcome. I am sure others have done it differently, but that's my go to way...
DT69Cam
10-13-2017, 05:55 PM
Honestly, I'm not sold on converting to AN fittings. I'm using a metric box and the fittings are pretty solid with no leaks. I would like custom bent tube ends like OEM.
dhutton
10-14-2017, 02:05 PM
Power steering hose from a C5 Corvette has the right fittings but is too short for a first gen F body. You could probably have one extended by a hydraulic hose shop.
http://www.ebay.com/itm/Power-Steering-Pressure-Line-Hose-Assembly-Pressure-Line-Assembly-fits-Corvette-/281954771527?fits=Year%3A2003%7CModel%3ACorvette&epid=75179853&hash=item41a5d06247:g:yGQAAOSwsXFZMfv8&vxp=mtr
It works great on A body cars.
There is a local shop here that will cut and braze etc to customize hoses. Might be one near you.
Don
DT69Cam
10-14-2017, 02:50 PM
Don
Thx Don
99socalfrc
10-17-2017, 01:37 PM
I converted to AN fittings and then bought some hose ends and PS hose to fit/ size the line myself.
DT69Cam
10-18-2017, 12:45 PM
Thx for the reply. I didn't want to convert to AN fittings and run hose from pump to the box. I want hard lines like OEM.
dhutton
10-18-2017, 02:30 PM
Hi Donny. Your hardline solution should contain a length of hose to absorb vibration like the OEMs.
Don
99socalfrc
10-19-2017, 11:49 AM
I've heard of some guys taking the OEM pump side end along with the box side end and having shops fuse the two by fitting the correct length of rubber between them.
Hope that makes sense, if you look at some of the OEM lines and how they wind around stuff this is a good option. The 98-02 Fbody pump that I used for example has a pretty one off shape to it. Starting with these and replacing the center hose section to size seems like a good option, though I have not tried it.
