View Full Version : 1964 Chevrolet SS Chevelle True 138 code – Frame Off
grr456
10-07-2017, 12:18 PM
1964 Chevrolet Chevelle True 458 code SS – Frame Off
I will attempt to list nearly everything. I have pictures of everything along the way.
I personally did everything myself over a 3 year period in my garage, except paint. Had a professional restoration shop paint the car for me. I can answer any question you may have.
64 SS had a 458 VIN Code not 138
Everything is 100% brand new on this car including 95% of fasteners most are AMK.
Body is unmodified and totally stock.
Original rust free California car, stripped to bare metal and painted.
Body was metal finished – No Filler
Original floor pans sanded and painted with Epoxy
Paint is 9.9 out of 10
Car weight is 3241
Schwartz Chassis – Powdercoated Black
New body bushings and bolts
Suspension modified for ZERO bump-steer
Rack and pinion power steering – Sweet collapsible steering shaft W/ Borgenson joints
Penske double adjustable coil-over shocks with canisters
Fully adjustable suspension and cross-corner weights
Brand New 383 Blueprint roller stroker – 450HP – 450 tq with dyno sheet.
Original 1972 Z/28 Intake and valve covers from a Z I bought new.
Kevko roadrace pan and pickup
Custom made coated headers and full 2-1/2 exhaust system. Plug wires run under headers
MSD distributor and box
Brand New Custom Black-Diamond BD-750 double pumper Quick-Fuel carb for road racing
Saldana custom dual pass aluminum radiator with electric fan
New alternator, power steering pump and high torque mini-starter
Quicktime Chevy/Ford dual pattern scatter shied
New Mcleod clutch and pressure plate
100% Brand new Autogear M23 (Muncie) close ratio transmission
New Hurst shifter with stock Muncie shifter lever
Brand new driveshaft and “U” joints
New Speedway Engineering NASCAR Ford 9” floater rear end.
Aluminum carrier with 3:70 gears and Tru-Trac gleason type drive
New 6 piston Wilwood radial mount calipers with 13” rotors up front
New 4 piston Wilwood conventional mount calipers with 12” rotors in rear
Hydratech hydroboost with fully adjustable CNC dual master cylinders
Brand new custom made stainless Fuel Tank by Ricks Tanks – Special for Schwartz Chassis
New #8 AN black braided fuel line
Trunk mounted Optima Red Top battery with new 01 gauge battery cables to front.
Rushforth 9.5 x 18 wheels with sticky Nitto NT-01 275-40 ZR tires - rear
Rushforth 8 x 18 wheels with sticky Nitto NT-01 245-40 ZR tires - front
Ididit tilt column with original steering wheel
Custom Autosound Radio
Tachman converted factory Tach and Clock – Clock now works
Dual front dash Stereo speakers
Bucket Seats and Original 4 speed center console
New carpeting
Also See https://www.pro-touring.com/threads/126163-An-Easy-Step-By-Step-on-Setting-Your-Car-Up-for-Autocross
rce789(at)yahoo.com
$68,000 – Less than I have in it.
Located in Troy, Mi
Finished
https://static1.pt-content.com/images/pt/2017/10/L1tFmfY-1.jpg
https://static1.pt-content.com/images/pt/2017/10/Z6Yk4J4-1.jpg
https://static1.pt-content.com/images/pt/2017/10/0Oo84vx-1.jpg
https://static1.pt-content.com/images/pt/2017/10/yVFr8ae-1.jpg
https://static1.pt-content.com/images/pt/2017/10/l8fW8X2-1.jpg
https://static1.pt-content.com/images/pt/2017/10/TAfm1fk-1.jpg
From Blasting
https://static1.pt-content.com/images/pt/2017/10/EHfSEi5-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4cNJTt0-1.jpg
https://static1.pt-content.com/images/pt/2017/10/8p75L82-1.jpg
https://static1.pt-content.com/images/pt/2017/10/wJe4inL-1.jpg
Bodywork
https://static1.pt-content.com/images/pt/2017/10/jHheTCL-1.jpg
In Paint
https://static1.pt-content.com/images/pt/2017/10/gX573rG-1.jpg
https://static1.pt-content.com/images/pt/2017/10/15lNhw3-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4NEShHf-1.jpg
Body on Chassis
https://static1.pt-content.com/images/pt/2017/10/SCwJKee-1.jpg
https://static1.pt-content.com/images/pt/2017/10/gUCqmtc-1.jpg
https://static1.pt-content.com/images/pt/2017/10/MICMQuO-1.jpg
grr456
10-07-2017, 12:20 PM
Rest of the pictures........
Underside
https://static1.pt-content.com/images/pt/2017/10/Epwm48V-1.jpg
https://static1.pt-content.com/images/pt/2017/10/6vV5pus-1.jpg
https://static1.pt-content.com/images/pt/2017/10/9WsU9cW-1.jpg
https://static1.pt-content.com/images/pt/2017/10/OTMIyZe-1.jpg
https://static1.pt-content.com/images/pt/2017/10/dJdfFb7-1.jpg
Exh – Looking back
https://static1.pt-content.com/images/pt/2017/10/xxmTLLY-1.jpg
Chassis
https://static1.pt-content.com/images/pt/2017/10/7AZGc7Z-1.jpg
Modified Rear Shock X-member
https://static1.pt-content.com/images/pt/2017/10/5GJhp3A-1.jpg
Engine/Trans/Rear
New Autogear Trans
https://static1.pt-content.com/images/pt/2017/10/D4GIiLn-1.jpg
https://static1.pt-content.com/images/pt/2017/10/Hczw8vW-1.jpg
https://static1.pt-content.com/images/pt/2017/10/6IMDAhX-1.jpg
Carb
https://static1.pt-content.com/images/pt/2017/10/2xt8prK-1.jpg
Rear Gear
https://static1.pt-content.com/images/pt/2017/10/QWBJaub-1.jpg
Engine Compartment
https://static1.pt-content.com/images/pt/2017/10/1wi9JIW-1.jpg
Trunk
https://static1.pt-content.com/images/pt/2017/10/mUUrjho-1.jpg
Headers
Putting together
https://static1.pt-content.com/images/pt/2017/10/0kSOcLZ-1.jpg
Finished
https://static1.pt-content.com/images/pt/2017/10/WNd6a6h-1.jpg
Steering Shaft
https://static1.pt-content.com/images/pt/2017/10/lVvCPeI-1.jpg
Fuel Tank – Custom made by Ricks Tanks
https://static1.pt-content.com/images/pt/2017/10/xdIKorq-1.jpg
Interior
https://static1.pt-content.com/images/pt/2017/10/wFzCRDG-1.jpg
https://static1.pt-content.com/images/pt/2017/10/oXU9k9L-1.jpg
https://static1.pt-content.com/images/pt/2017/10/6QlLCCo-1.jpg
https://static1.pt-content.com/images/pt/2017/10/USLUvrI-1.jpg
1965_SS
10-19-2017, 10:12 AM
Real nice car!
I think your weight is off though.
grr456
10-19-2017, 12:10 PM
Real nice car!
Ummmmmm, I don't think so.......
Go here....
https://static1.pt-content.com/images/pt/2017/09/EZr4Eqn-1.jpg
grr
Fuelie Nova
10-19-2017, 03:13 PM
Go here....
grr
I think he meant your add says total weight is 2341
Tom
1965_SS
10-19-2017, 03:31 PM
Tom
Yes
grr456
10-19-2017, 04:44 PM
Ooops, thanks...Got a little dyslexia happening here...
grr
