View Full Version : LS2 Temperature Sensor / 67 Camaro
1967ls2
10-07-2017, 12:12 PM
I am currently running a standalone temp sensor I mounted in the passenger side head to an auto meter gauge in the dash.
I'd like to utilize the OEM sensor that is mounted in the driver side head from the factory that the computer uses.
Has anyone done this? Would I just tap into the harness and extend the signal wire to the auto meter gauge?
andrewb70
10-07-2017, 12:14 PM
Temperature sensors are thermistors and work through variable resistance, like a gas level gauge. The signal can't be split and each gauge is looking for a particular resistance vs. temperature curve. So you can't do what you want to do...
1967ls2
10-07-2017, 12:42 PM
Bummer.
1967ls2
10-07-2017, 12:44 PM
If that is the case, how does the 05 GTO or Corvette receive input to the stock gauges for coolant temperature? Do they take it from the radiator or another source?
1967ls2
10-07-2017, 01:57 PM
Did a little searching and it looks like I could possibly run a 3 wire ect sensor.
dhutton
10-07-2017, 02:26 PM
Those gauges get the temperature data from the ECM. Dakota Digital VHX gauges can read the temperature etc data from the ECM and don’t require dedicated senders.
Don
andrewb70
10-07-2017, 03:20 PM
How will that connect to the ecu and your gauge? Both are looking for changes in resistance, not a 0-5v signal.
1967ls2
10-08-2017, 07:33 PM
I found this post here https://ls1tech.com/forums/conversions-hybrids/1678789-ls-guys-doing-swap-3-wire-coolant-sensor-conversion-part-numbers.html
Looks like these guys were trying to do the same thing and accomplished it with a 3 wire sensor.
I assume with my standalone harness there is nowhere to take the signal from the ecu to the gauges which is why I started this thread to see if there was any other options.
1967ls2
10-08-2017, 07:58 PM
Yeah after doing some more research, looks like the 3 wire sensor is from a 98 LS1 and hooking the third wire up to the gauge will work but it'll be about 10-20 degrees off. Bummer again.
SSLOW6.0
10-09-2017, 03:51 AM
Measure the resistance at 0 and 100 degrees C. with an Ohm Meter, then repeat with your gauge. With a little bit of math and properly sized resistor you should be able to get it to line up.
I used a 3 wire sensor on my 86 Monte Carlo SS and the resistance lined up to temp perfectly.
1967ls2
10-09-2017, 09:13 PM
Yeah, I was thinking about wiring a resistor in line but wasn't sure. I had to do that for the tachometer to work properly given the pulses, etc. I just was hoping someone else may have done this first and confirmed they were able to get it working before I go through the headache of rewiring everything.
dhutton
10-10-2017, 03:07 AM
Keep in mind that the resistor you add doesn’t vary with temperature. The more you add the bigger the effect will be....
Don
