View Full Version : Fitting from hardline to PTFE hose?
cpd004
10-05-2017, 10:40 AM
As far as I can tell, there is no other direct 3/8" tube to PTFE -6 hose fitting available other than from TechAFX. Does anyone have any experience with this fitting or is there a better solution apart from going multiple fittings?
http://www.techafx.com/content/new-6-hose-38-hardline-fitting
gbledsoe3
10-05-2017, 11:03 AM
I bought Earl's fittings from Summit Racing to transition from 3/8 to -6AN.
https://www.summitracing.com/parts/ear-165006erl
cpd004
10-05-2017, 12:02 PM
Thanks for the link.
MuscleRodz
10-09-2017, 07:10 PM
just need standard an union, ptfe -6 fitting on one end , an -6 tube nut and sleeve on the other end unless your looking for something special.
parsonsj
10-09-2017, 08:27 PM
What Mike said.
6AN tube nut and sleeve, flare to 37 degrees, connect to AN union. That way the tube is constrained on both the inside and out for a trouble-free connection.
I think Andrew (andrewb70) has a video of this on his build thread.
cpd004
10-10-2017, 03:50 AM
This connection is for a fuel line (3/8" tube) that is already under the car with no fitting on the ends. I was going to use this compression type of adapter to attach what I thought was a short run of -6 line from the tank (turns out is -8). This was so that I didn't have to take the line down and snake it around the axle to flare it. After looking at it for a while last night, it looks as though I'd be able to get it down enough to flare it. As far as I can tell, -8 tube nuts/sleeves are for 1/2" tubing.
The above link for the transition is available to adapt from 3/8" tube to -8 PTFE line. Or I'd have to flare it for -6 and get a reducer/union.
andrewb70
10-11-2017, 09:46 AM
I have used the compression fittings before, but prefer to flare the tubing and use tube nuts, sleeves and AN union fittings...
http://www.youtube.com/watch?v=46hFmkTGGV8
