View Full Version : StopTech Brake Install on Pro-Touring Car
Ron Sutton
09-16-2017, 08:12 AM
https://static1.pt-content.com/images/pt/2017/09/20170915_192725X2-1.jpg
Lance Hamilton just received his StopTech Brakes designed & optimized for Pro-Touring Cars by Ron Sutton Race Technology.
These are the ONLY brake systems that do ALL this:
* Provide more braking force than a ZR1 or C7 Corvette
* Have the most Rigid Calipers, Big Piston Area & 14" Aero Rotors & Hats
* Designed specifically for Manual Brake Pro-Touring Cars doing "Triple Duty"
* Utilizes ONE PAD for Street & Autocross with great cold bite & Track Days up to 1200° with zero fade !!!
* These Pads are new "Adhesive Technology" = low dust, low squeal, long life, low cost AND don't eat up rotors!
* No other brake system on the market today compares
Learn more here: http://www.ronsuttonracetechnology.com/catalog/?page=94
Let's follow Lance doing the install & then street test & autocross days. :)
toddz69
09-26-2017, 09:19 PM
Looking forward to seeing how this goes!
SSLance
09-27-2017, 02:20 PM
Me too!! We think we know what the carb issue is and a fix is in the works. If all goes good I'll make it with Barney to our last race of the season in KC on Oct 29th.
Shortly after that we are moving to Phoenix where hopefully I'll be able to race it locally through the winter.
malibudave
09-28-2017, 11:38 AM
Ron,
Sweet.
What is the piston area and weight of those calipers?
Dave
SSLance
09-28-2017, 03:48 PM
Dave, I can't answer the piston size question but I did compare the weight of the stock G- body spindle, rotor and caliper and compared it to the ATS spindle, and Stoptech Rotors and sT60 caliper.
Stock setup
https://static1.pt-content.com/images/pt/2017/09/20170918_125931X2-1.jpg
Stoptech setup
https://static1.pt-content.com/images/pt/2017/09/20170918_130212X2-1.jpg
toddz69
09-30-2017, 10:19 AM
Great! I live in Phoenix so perhaps our paths will cross.
Todd Z.
SSLance
10-26-2017, 12:11 PM
Cleaned up and ready to race...
https://static1.pt-content.com/images/pt/2017/10/20171026_140025XL-1.jpg
Will be attending the last Kansas City Region SCCA Autocross this Sunday, can't wait to feel how these do on track.
jumbosrule
10-27-2017, 09:30 AM
Hopefully you can get somebody to take some action shots - good luck!
toddz69
10-27-2017, 01:56 PM
When you get a chance, I'd be interested in piston areas and what master cylinder you're using.
Todd Z.
Ron Sutton
10-27-2017, 02:51 PM
Todd Z.
In the front, we run piston sizes of 38mm, 40mm & 42mm for a total piston area of 5.85" per caliper.
In the rear, we run piston sizes of 32mm & 36mm for a total piston area of 2.825" per caliper.
This creates a 67.5%/32.5% Front/Rear Brake bias with the same size calipers.
We Tailor RSRT Manual Brake Systems to what the driver wants:
Super Firm Pedal – Utilize a 5.5-1 Pedal & 15/16” M/C
Firm Pedal – Utilize a 6-1 Pedal & 15/16” M/C
Moderate Pedal – Utilize a 6-1 Pedal & 7/8” M/C
Light Pedal – Utilize a 6.25-1 Pedal & 7/8” M/C
Ron Sutton
10-27-2017, 04:21 PM
If you're coming to SEMA, drop by the StopTech booth #24435 & see my new 1-pad for Street, AX & Track Muscle Car Pro-Touring Brakes.
We're giving out SWAG if you mention you saw this post on Lateral-G.
:cheers:
toddz69
10-28-2017, 09:16 PM
Thanks for the info, Ron.
Todd Z.
- - - Updated - - -
:cheers:
What if we say we saw it on Pro-touring.com? Still qualify for some swag? :)
Todd Z.
Ron Sutton
10-29-2017, 02:09 AM
Yes sir!
SSLance
10-29-2017, 04:43 PM
There were at least three official photographers at today's event so I'm sure some will surface in the next couple of days.
SSLance
10-29-2017, 04:57 PM
Had a great day today, fantastic fast and fun course with two hard braking zones to try the new Stoptech brakes out on. It was cold too, 25 degrees to start the day, somewhere around 40 degrees when we started our heat. I must say, I thoroughly enjoyed not having to worry about warming my brake pads up as I headed for the start on my first run.
Being the first time on track with these brakes (and a whole other host of new parts including shocks and steering) I really didn't know what to expect, but I was familiar with the course as we ran the exact same course at this event last year. As I sailed it into the first hard brake zone, it immediately started wheel hopping the rears probably from too much bias. I saved the corner and braked a bit earlier and softer for rest of the run. Once back in grid I backed a bunch of rear bias out. On the next run, no rear wheel hop but I slid the inside front tire once I started to turn the steering wheel. Before each of the next two runs I added a bit more rear bias back in and I think I got it pretty close on last run.
I must say, these things are fantastic! Even though they are set up for a manual system, I'm running them with my stock power booster...and it is still very easy to modulate them to get great stopping without locking the tires up. Loved the extra confidence knowing I can sail it into the very fast corners and not have to worry about whether it'll stop or not. I ended up about 1 second faster on a 46 second course than I ran last year and finished 3rd in class, 15th overall raw time out of 165 drivers. I'll take that!!!
Here is a video of all 4 of today's runs. Remember, this was the totally brand new setup's first time on course.
https://youtu.be/joT4uyggPqQ
The unofficial results are here...I know there be a few changes once official and I'll try to post them up in a day or so.
https://kcrscca.org/solo/live/results_live.htm#camc
If any questions about what they are like to race with, ask away.
beater65
11-03-2017, 12:50 PM
I'm super jealous of the level of engineering and parts applied to your car. Hope to get that far along on mine one day.
Nice work. Glad you are able to document your journey and provide a lot of great tips for rest of us.
