BMR Sales
08-24-2017, 06:26 AM
BMR Suspension Adjustable Upper Control Arms for 1964-1972 GM A-Body
UTCA043, UTCA044
UTCA046, UTCA047
Launching harder, reducing wheel hop, and adding cornering consistency to your 1964-1972 GM A-Body is easy with adjustable upper control arms from BMR Suspension. The stock stamped steel control arms with soft rubber bushings deflect under load and absorb power instead of transferring it to the tires. BMR’s on-car adjustable tubular upper control arms for GM A-Body (UTCA043/UTCA046 – poly, UTCA044/UTCA047 – rod end) are manufactured from heavy-duty CNC-machined 1 1/4 inch DOM steel tubing. The center adjusters are CNC-machined from chrome-moly steel with rolled threads for the ultimate in strength and durability. This design gives you an incredibly strong control arm that greatly improves performance. BMR Suspension designed the UTCA043, UTCA044, UTCA046 and UTCA047 to work well in street performance, drag race, and handling applications. The heavy-duty construction eliminates control arm flex, giving you much improved repeatability on the street, starting line, or in the corners. The adjustability allows you to dial in pinion angle for correct driveline geometry. BMR’s upper control arms offer tons of articulation for great handling, while giving you more than enough strength to stand up to high loads of any performance environment. When performance is a must, rely on BMR Suspension! Installation time is only 2-3 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com (http://www.bmrsuspension.com/), email [email protected], or contact them at BMR Suspension, 928 Sligh Avenue, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
143464143465
UTCA043, UTCA044
UTCA046, UTCA047
143464143465
