View Full Version : 9" Rear End Jig
1bad68cat
08-23-2017, 06:50 AM
Just wondering if anyone in San Diego, CA has a rear end jig that I can borrow or purchase. I'm getting ready to weld my axle brackets to my 9" and want to make sure the rear end housing stays straight. I may be willing to take it to a shop to weld if the price is right. I currently have the brackets tacked into place.
Thanks in advance.
65 drop top
08-24-2017, 03:06 PM
Maybe a little too far for you to go, but Earl Williams at Williams Classic Chevy is top notch. He's located in La Verne, which is next door to Pomona.
1bad68cat
08-25-2017, 04:50 AM
Thank you for the suggestion. I'll look into Earl if I can't find anyone local.
dontlifttoshift
08-25-2017, 05:09 AM
The jig won''t hold the axle housing straight when welding the brackets on, it will only show how far off the alignment is when you are done welding.
1bad68cat
08-25-2017, 05:24 AM
How so Donny? Unless the alignment bar is installed after welding the brackets on. I've always installed everything prior to welding. At least that was the way I was taught.
dontlifttoshift
08-25-2017, 07:37 AM
The alignment bar isn't anywhere near strong enough to keep an axle tube from pulling out of alignment during welding. It's an alignment tool, not a fixture.
When welding brackets on to an existing housing, after tacking them in place, I check the alignment. If it's close, I weld away. If the brackets are 360* around the axle it usually doesn't move much as long as you weld all the way around in one pull.
If it's way off, we decide if the required weld is going to help or hurt us. From there we will straighten the housing or just cut the ends of and start from scratch with the alignment.
If the brackets are the less than 180* it will pull to that side and I usually correct that with more weld on the opposite side of the tube.
The bearing pucks will slide in and out of the housing ends without too much effort and still be misaligned.......they need to slide in with zero effort.
