Ron Sutton
08-18-2017, 12:38 PM
Today is THE Day! Launch Time!
10 New Product Lines
3000 New Products
3 Years in Development
New Catalog:
Its Big! 400 Pages Big !
Its Full of Go Fast Cars, Parts & Kits
From Chassis, Suspension & Brakes ... to Engines, Drivetrain, Aero & More
It is Your One Stop, Turn & Go Fast, Car Building Resource Center
For Autocross, Track Cars, Road Racing & Triple Duty Pro-Touring Cars
3 New Product Lines for Ford & GM Muscle Cars:
AutoX-Star Packages
AutoX-Warrior Packages
Track-Star Packages
Track-Warrior Cars:
4 Levels: From the Base Model TT to TA2 & TA and the Top of the line GT
4 Ways: Turn-Key Track Car / Rolling Chassis You Finish / BYO Kits / Part by Part
Suspension Packages:
4 Levels of Front Frame Clips with Suspension & Steering / Custom Built for Your Car
4 Levels of 3-Link Rear Suspensions with, or without, frame rails & rear ends
Including 2 Levels of our Infamous Race Dominating Decoupled 3-Links
Torque Arm Rear Suspension Packages with, or without, frame rails & rear ends
Quik-Tune Shock Mounts in 18 Versions
Double Adjustable Quik-Tune Panhard Bar Kits 6 Versions
The Ultimate Quik-Tune Watts Link Package 3 Welded Versions & 2 BYO Versions
StopTech Triple Duty Brakes:
Designed & Optimized by Ron Sutton to be the Best Brake System for Street, Autocross & Track
Amazingly utilizes only 1 Pad for Street, Autocross & Track
Front Applications: GM A, F & X Bodies, C5/C6, Speedtech, Ridetech, DSE & RSRT
Rear Applications with Parking Brake: 9 Ford, 10/12 Bolt GM & Speedway Floaters
More Applications Coming by End of Year
Warrior Engines by Ron Sutton & SDPC RaceShop:
12 Powerful LS Engine Packages
From 550 to 900 HP Naturally Aspirated !
Wet Sump & Dry Sump Oiling Systems
Most Linear Power Curve Available on the Market
Built Better, Stronger & More Durable with Higher Grade Parts
Plus Scott Clark Pre-Programmed ECUs & the Best Accessory Drive Systems
Wide Range of Engine Accessories to Complete Your Powertrain:
Holley HP & Dominator EFI ECUs & Harnesses
Drive Junky - The Best LS Accessory Drive Systems / With or Without AC / 3 Finishes
Holley & Canton Road Race Wet Sump Oil Systems & Accusumps
ARE Dry Sumps Systems for All LS Engines
Motor Mounts & Adapters / Motor & Mid Plates
Bolt On Headers & Build-your-Own Header Components
Drivetrain Products to Complete Your Mean Machine:
Blueprinted T56 Magnum 6-Speeds & Sequential Shift 6-Speeds in 3 Ratios
Complete Ford 9 3rd Members / 4 Differential Options / 7 Gear Ratios
Detroit Lockers & Tuning Springs / Ring & Pinions & Install Kits
4 Levels of Clutches / LS Bellhousings / 3 Levels of Custom Driveshafts
Cooling & Plumbing:
Radiators from Basic to Advanced with Built in Coolers & Fans
19 Coolers for Engine Oil, Power Steering, Trans & Rear End Coolers
Every Overflow, Vent Tank & Accessory Needed
A full 22 Pages of Plumbing Hose, Hard Lines & Fittings
Cutting Edge New Products:
AutoX-Star Control Arms for Muscle Cars Higher Caster & Motion Ratio
Billet Steel, Slugged Centerlinks for Optimum Bump Steer
Shock Rocker Arms for Pushrod, Pullrod or Rocker Arm Suspensions
Trick New Coil-Over Shock & Spring Accessories
New and I mean NEW Power Steering Pump with Tunable Flow Rates
Public Release of Trick Products:
Billet Steel 3-Link Top Link Adjuster & Extension Rod Kit
3-Piece Sway Bar Kits / Front & Rear / Easy to Weld In
Ron Sutton Configured Full Containment Race Seats at Only $899
Low CG Fuel Cells for Street & Track with All the Features
Custom Made Splitters & Advanced Downforce Wings 15 Versions
Stuff to Build-Your-Own Stuff:
New Laser Cut Rear Frame Rails & Crossmembers with Special Features
Every Trick Part & Piece We Use Available to You the DIY Car Builder & Pro Shops
Every Bracket, Tab, Slug & Mount You Need
Trick New Bay Bar Spuds & Roll Cage Dimple Die Gussets
Our Powder Coated, TIG Welded 1.25 OD Suspension Tubes in DOM & 4130
Everything you need to build your own car from Sheetmetal to Plumbing
Tools-Tools-Tools:
The Trick Tools to help You Build-Your-Own AutoX or Track Car
The Best Tools to Setup Your Car Before Events
The Optimum Track Tools to Know Whats Up & Dial In Your Car at the Track
Ron Sutton Tech Services:
Services Where Ron Works Direct with You on Your Car Project
Suspension Tech Services to Optimize Your Production Car
Chassis Design Services to Build the Mean Car of Your Dreams
Plus Calculation Services to Optimize Your Brakes, Gearing, Powertrain, Aero & More
Ron Sutton Secret Sauce Valved Shocks:
Ridetech Single & Triple Adjustable / 2.9 Stroke to 6.9 Stroke
JRI Triple Adjustable / 4 Stroke to 7 Stroke
AutoX-Star, Track-Star & Race-Star Valving / Front & Rear Specific
Plus The Full Line of Draco 9000 Series Quick Response Coil-Over Springs
Lower Prices on Key Items:
RSRT Awesome GT Spindles & GTR Rear Steer Spindles Now Only $799
Roll Cage Packages / 4 Versions / All Cars / Starting at only $799
HANS III devices in 4 Versions / Only $549
Forgeline Wheels / All Versions / Special Pricing
Dealer Listings:
Work with RSRT Direct or One of Our Authorized Dealers
Ron Works on Your Project with Your Chosen Dealer / Same Great Tech Support
Find an Authorized AutoX-Warrior Installer near You
Pick the Best Authorized Track-Warrior Builder for You to Work With
Thats all.
Just 400 Pages of Most Complete & Comprehensive Line of Products & Services to Assist You in Building Your Ultimate Autocross, Track Car, Road Racer or Triple Duty Pro-Touring Car.
Ron Sutton
See it ALL in our New 400 Page Catalog HERE! (http://www.ronsuttonracetechnology.com/catalog/?page=1)
143319
3000 New Products
New Catalog:
AutoX-Star Packages
Track-Star Packages
Track-Warrior Cars:
Cooling & Plumbing:
Tools-Tools-Tools:
Dealer Listings:
Thats all.
Ron Sutton
143319
