View Full Version : EFI fuel vent installation
Simon J
08-16-2017, 06:15 PM
Hi all,
I just changed my fuel tank from stock to a Tank inc. fuel tank with in-tank pump. The tank came with a vent.
I understand it has to be installed in an upright position as high as possible (I understand it has to be higher than the filler neck if possible).
I thought about putting it in the driver's side wheelwell but the tire will probably be rubbing on it (I don't have mini-tub and I run 255s out back).
Where do you guys install the vent?
Thanks a lot,
MIGHTY MIKE B.
08-17-2017, 05:26 AM
143277 Used a remote 2 much Farication vent mounted in back of trunk with line comming from tank and a line going back out the bottom of trunk to filter.
Simon J
08-17-2017, 11:02 AM
Thanks Mike,
Does it smell in the trunk? I use my trunk a lot and being a convertible there is no separation between inside the car and the trunk.
Also, I read that sometimes the vent could spill gas.
Simon
all4sho
08-17-2017, 03:00 PM
good question, i have the same problem but have not got that far yet in the build
MIGHTY MIKE B.
08-17-2017, 04:22 PM
There is no smell in the trunk. I have the vent to air under the trunk. I do not smell fuel in the garage when i uncover the car to leave either. The top of the canister is higher then the fuel fill and keeps fuel from going out. I have been happy with it.
ULTM8Z
08-17-2017, 05:54 PM
You can see what I did in this thread....
www.pro-touring.com/threads/120176-Efi-fuel-tank-venting?highlight=Ultm8z
CliffsBlueCamaro
08-18-2017, 03:40 AM
Nice! I really like how your setup vents straight into the filler neck.
What do you think about a set up like yours that just goes through a charcoal canister before the filler neck, with no vent valve?
ULTM8Z
08-18-2017, 08:13 AM
Well, you need a fresh air intake. My system pulls from the filler neck, but without the vent valve, if be pulling a vacuum in the tank, and could potentially collapse it.
MAGONSTERZ68
08-20-2017, 09:38 PM
Ricks resto mod tank in 68 Camaro, I Used a sand cars specialties roll over tank valve routed from filler neck to out and behind license plate with zero issues.
