View Full Version : Flush Valve Stem Problems
Hemi8
08-11-2017, 01:07 AM
Are there any options for fill valves for flush valve stems? I have Mr. Gasket flush valve stems but cannot fill the tires with air because the fill valve that screws in for checking/adding air is too tall. The fill valves hit the rotor, so I have to remove the wheel to add air. These are Coys wheels which place the fill valve in the worst place possible. I need a 90 degree fill valve but can't find a source. I only have about .35" between the flush valve cap and the caliper so I don't think a regular short valve stem would work. These are 18" Coys over Corvette C5 brakes.
Mike
OLDFLM
08-11-2017, 08:18 AM
How much clearance do you have to the rotor? Rotate the wheel past the caliper? I know the flush mount caps behind the wheel center can be a pain...
Worst case drill a hole in the front lip and put in a regular valve stem... problem solved.
Hemi8
08-12-2017, 02:42 PM
That was my initial idea, just drill a hole to re-locate it, but the shop I took the wheels to was not equipped to do it properly so I didn't do it. Now I regret not taking somewhere else, now I have to, if I can't find a short screw-in fill valve.
Mike
1bad68cat
08-14-2017, 04:17 AM
Would something like this possibly work?
https://www.motomummy.com/valve-stems/bridgeport-90-degree-angled-valve-stem-set/
Hemi8
08-14-2017, 06:59 AM
I was looking at that type yesterday but I think motorcycle wheels have a diff. size hole for the valve?
Mike
OLDFLM
08-14-2017, 12:37 PM
I'd contact someone at Forgeline or Rushforth wheels for advice... I'm sure they've addressed this issue before.
