View Full Version : LS2 Accessory Brackets
Phillip_L
11-23-2005, 01:41 PM
I am trying to put a part list together for a LS2 going into a 1969 Camaro. Do I have to spend the $1,800 for the Street & Performance kit or will factory brackets work? I know you can not mount the A/C without knotching the subframe.
Thanks.
Phillip
datsbad
11-24-2005, 08:42 PM
did you go to LS1TECH.COM ? go over there and do a search , there is a conversion forum with many questions answered . I used street and performance's mounts and pan . no issues at all , and i am using them again for my next car .
Damn True
11-28-2005, 10:46 AM
Just for referance, can an AC compressor be mounted in a 1st Gen chassis with an LSX?
I'll go to LS1-tech when the time comes for the details, just looking for general info at this point.
parsonsj
11-28-2005, 10:57 AM
DT,
Yes, it's been done. I believe the subframe had to be notched though.
jp
Damn True
11-28-2005, 11:15 AM
Drat.
derekf
11-29-2005, 12:07 PM
True, I believe Tyler (or one of his folks) has announced that they've got a solution for AC in that case on its way.
chicane67
11-29-2005, 08:55 PM
Its in development, but no ETA as of yet.
datsbad
11-30-2005, 07:37 PM
I did just hear that Vintage air is releasing something also
Steve1968LS2
11-30-2005, 08:02 PM
DT,
jp
Yea, by BRP.. I don't like several things about that design.. one is pushing the motor too far forward and the other is the funky sway bar flip..
AC is overated anyways ;)
Ralph LoGrasso
11-30-2005, 10:35 PM
:icon996: Exactly-- if you get hot, just roll the windows down and drive faster. :)
Steve68
12-01-2005, 03:41 AM
Come live in FL for awhile you two yahoos
Damn True
12-01-2005, 06:54 AM
I'd be inclined to agree with you on all but a few days. But, the wife-to-be sees things a little differently. AC probably wont be a part of the initial build but it will happen eventually.
SatisTraction
12-01-2005, 10:51 AM
it can be done but it is not a bolt in if you use the S&P style mounts.
chicane67
12-01-2005, 09:34 PM
Try Vegas........
Steve68
12-02-2005, 09:24 AM
Sorry Tom, forgot about the nice dry heat in Vegas and the High Desert of CA, When I was there in July it was only 108 on the lake bed, Nothing like the nice cool climate of Coastal CA,
Sorry, Gotta have AIR!
michmadman
01-29-2006, 12:38 AM
You should try www.synisterproducts.com (http://www.synisterproducts.com) They may have a solution.
scogin918
01-31-2006, 03:53 AM
I had to notch my subframe for the compressor. I just received the bracket from Vintage Air to mount the Sanden compressor in the stock location. It's either that or using S & P's top mount set up that puts it up high on the passsenger's side.
datsbad
01-31-2006, 05:21 AM
scogin918 , I have to ask , what mounts are you using with the LS1? S&P's mounts require alot of clearancing of the subframe to get it to fit . I have the same bracket you speak of . I would be interested in seeing some of your work in this area.
