View Full Version : BMR Suspension New Product - Coil-Over Conversion Kit for 78-87 GM G-Body - CCK007
BMR Sales
07-31-2017, 01:05 PM
<style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} a:link, span.MsoHyperlink {mso-style-unhide:no; color:blue; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {mso-style-noshow:yes; mso-style-priority:99; color:purple; mso-themecolor:followedhyperlink; text-decoration:underline; text-underline:single;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt;} @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} --> </style>
BMR Suspension Coil-Over Conversion Kit for 78-87 GM G-Body
CCK007
Increase traction, add ride height, and improve suspension geometry adjustability to the rear of your 1978-1987 GM G-Body with a Coil-Over Conversion Kit from BMR Suspension. OE-style lowering springs can drop the vehicle, but do so at the expense of suspension and shock travel. By utilizing a conventional coil-over, the vehicle can ride at a lower ride height, while still retaining full suspension travel. BMR manufactures its Coil-Over Conversion Kits from CNC-laser cut, CNC-formed 1/4-inch steel plate for strength, lightweight, and precise fitment. These mounts add three extra mounting positions for the lower control arms, allowing you to change instant center and anti-squat geometry. Whether you want to aggressively lower your G-body or you want the added suspension control you get with coil-overs, BMR makes it easy to add coil-overs to the rear of your car. This kit is designed to work with any coil-over with a 1.25-inch wide bushing and ½-inch bolthole. BMR Suspension’s CCK007 Coil Over Conversion Kit is available in black hammertone and red powdercoat for long-lasting good looks. Installation time is 2-3 hours. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com (http://www.bmrsuspension.com), email [email protected], or contact them at BMR Suspension, 928 Sligh Avenue, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
142782
