View Full Version : BBC camaro will not start
mtm87tx
07-26-2017, 09:47 PM
Team,
Can you please help me trouble shoot my car it is not starting:
When you turn the ignition one click everything lights up fine, shows voltage, radio/ac work
When you turn the key to start it makes one click which sounds like the starter solenoid and then voltage drops to 0
The starter is new
The battery is new
If i leave battery cables on it from the charger and wait about an hour the car will start. It will only do this once
Any thoughts? I have checked the visible wires, cleaned the terminals, etc
232_ray
07-26-2017, 10:25 PM
Mine was acting sorta the same. Make sure that the positive and negative cable are hooked up properly. As in tight and not grounding out on something else. Just check the terminals. They might look good but mine weren't actually as good as they looked.
blitzer454
07-27-2017, 06:08 AM
It sounds to me like you have a bad battery, or something is draining the battery when the car is off. What was the battery voltage before you tried starting the car?
