View Full Version : best looking and most functional efi for sbc
nvawgn
07-26-2017, 02:52 PM
looking for a cool looking EFI that is the most functional system available, any ideas?
i like the looks of the edelbrock unit
142693
TheJDMan
07-26-2017, 07:28 PM
I had heard that FiTech was going to be offering a port injection system using the Edelbrock manifold.
nvawgn
07-27-2017, 06:28 AM
thanks JDM
Fuelie Nova
07-27-2017, 09:23 AM
How much flexibility do you want?
Tom
nvawgn
07-27-2017, 12:26 PM
i don't know much about EFI, just the fact that it's easier than adjusting a carb every other day. can u explain flexibility, thanks.
andrewb70
07-27-2017, 02:28 PM
I wouldn't say that it is easier, but it certainly gives you the ability to tune an engine a lot better than a carb. The hardware part is fairly simple and you probably have only a handful of choices. As for the actual computer and software, I have really been impressed with the Holley EFI systems, both the HP and the Dominator. You can use the Edelbrock intake with the Holley ECU.
Also, don't forget that for easier tuning, you want to choose a camshaft that will give you the most vacuum at idle. At a minimum 14-15 in/mg...but the more the better.
TheJDMan
07-27-2017, 02:34 PM
What he is asking about flexibility is how much control do you want to have over the EFI system or are you willing to allow the EFI to self-learn. Higher end systems (read more expensive) allow you to control every aspect of the fuel curve where more user friendly systems will self-learn and limit the user controlled settings. Since you are new to EFI you don't want a high end system you need one that will self-learn AKA, FiTech.
nvawgn
07-28-2017, 07:27 AM
thank u andrew and steve, yes that sounds better, something i can learn along the way.
