View Full Version : REASN67 - My 1967 Camaro build
reason
07-25-2017, 07:32 AM
Haven't posted much on this forum over the last few years since joining, but wouldn't have been able to get as far as I have without the help from everyone's own builds/posts here.
Finally getting into the last leg of my build and thought I should share my own journey as well to try and help return the favor.
I'm going to go back in and update my posts with details/info as I organize it, so bare with me for a few days.
Cheers,
and thanks to the community for inspiring a lot of the decisions as I've been building mine.
CHASSIS / SUSPENSION
ENGINE (PLACEHOLDER)
TRANSMISSION
BRAKES
DSE Hydroformed Subframe
LS1(2000 Camaro Pull)
Tremec T56 Magnum Close Ratio
14” BAER Pro+ 6 piston
DSE Subframe Connectors
C6 Oil pan
QT SFI Bell Housing
13” BAER SS4+ 4 piston with Park Brake
DSE mini-tub
Detroit Speed 1 ⅞ Stainless Longtubes
Science Friction Atomic Twin Clutch
BAER Remaster Cylinder 1 1/8
DSE Firewall Smooth Panel
ProForm Valve Covers
Science Friction Billet Steel Flywheel
HydraBoost
DSE 1/2 height Body Mounts
Vintage Air Front Runner System
X-Factor aluminum Cross member
Single Adjustable JRi CoilOvers
ELECTRICAL/MISC
INTERIOR
REAR END
WHEELS
WiringSpecialists Engine Harness
Recaro “Specialist S” Seats- Black Leather
Detroit Speed QUADRA Link 4-link
18" Forgeline DE3C
American AutoWire Chassis Harness
Speedhut Revolution Gauges
Shortened Ford 9” w/ 3.89
18" GM Heritage Steelies
LSX independent Fan Controller
Vintage Air Air/Heat
Clayton Machine Works Pedals / Shifter
Ridetech Billet Locking Fuel Door
Shop LLC - 6.5" Kick Panels + 6x9 Rear Tray
DSE Selecta Speed Wiper Kit
DSE "600 Series" Super Tank - Narrowed
I'm sure im forgetting a lot of parts - will try and post a full build sheet once done.
If anyone has any questions feel free to reach out-
reason
07-25-2017, 07:40 AM
Where to start the story. Ill probably come back in and update this a bit more... but long story short, have been dreaming of building a pro-touring camaro for a number of years. But wanted to find a good car to start with that I wouldn't feel guilty about hacking apart.
The goal was to do all the work myself and use it as a learning experience. It's definitely been that.
Here she is when I picked her up:
1967 Camaro - 327 V8 with an automatic.
Decent body, 5' paint job and pissing fluids out of just about every place she could.
Hindsight if i knew how far into the project I was going to go, I probably would have gone for something a bit more WIP... but i got a decent deal on the car as is. Visually the car was in good shape for a daily driver... mechanically it was a disaster. Motor + Trans were shot. Rear end was a mess, and after tearing her down we discovered she was missing half her bolts and the brake pads in the drums.
Lucky for me... and unbeknown to the seller none of that stuff was staying in.
So was able to negotiate a pretty decent deal on her.
142598
reason
07-25-2017, 07:50 AM
Placeholder Post
reason
07-25-2017, 07:52 AM
THE TEARDOWN
After placing a fairly hefty parts order to get things going, its time to tear her down and see what I'm really working with.
reason
07-25-2017, 01:54 PM
Interior teardown
142642
142641
142640
142639
reason
07-25-2017, 02:11 PM
TEMP MOTOR PULL / CLEANUP
Still debating on my final motor build, plan is for a twin turbo build once i get the car all wrapped up and dialed in. But for the time being needed an LS1.
Picked up a 2000 Camaro with a solid motor for dirt cheap. Just needs a bit of a refresher and clean up.
Timelapse of the pull:
https://youtu.be/R83r2lHXuHM
gator68428
07-25-2017, 02:30 PM
4 wheel drums, gotta love it. That's how mine started.
I also was backlogging my posts in my project thread. My build started when I was 15 in 1999 and started PT-type mods in 2006 and learned of this site in 2015. Feb of this year was when I started my proj thread and have trying to detail all the relevant events. Good idea on the placeholder posts, I should have added some! As it turns out, Just yesterday my thread finally became current--and it has 90% of the details I wanted, so I'm pretty relieved right now. Lucky for you and I was that we got started after the photobucket debacle.
Looking good so far. I think you started with the perfect vehicle. A very nice shell with weathered mechanicals. Looks like you ponied up for the good stuff too. Looking forward to this one.
CliffsBlueCamaro
07-25-2017, 07:32 PM
Agreed on all points, Mitch! I was just about to compliment the layout - very good for a build update on a badass car. Can't wait to see it come together!
reason
12-25-2017, 10:13 PM
Engine Pulled + Initial Cleanup
147243
147244
147245
147246
147247
And thanks to American Powertrain...
147248
reason
12-25-2017, 10:18 PM
DSE Quadralink Mockup + Mini Tubs
147253
147254
147251
147252
reason
12-25-2017, 10:28 PM
Mocking up the DSE Subframe + Motor
147255
147256
147257
147259
Hmm... gonna need to make some room...
147260
147261
147262
Picked up an Auto Twirler to make life a bit easier...
147263
reason
12-25-2017, 10:32 PM
Transmission Tunnel
Highly recommend Bowler Transmissions Tunnel Patch if youre looking to make some room
147264
reason
12-25-2017, 10:48 PM
Undercarriage Prep + Metal Repair + Firewall Cleanup
Aight - lot of steps going into this... a lot of grinding.. and a lot of sweat.
147268
147269
147270
147271
147272
147273
147274
147275
147276
147277
147280
147279
Seam Sealing...
147281
UPol Raptor Liner - this stuff is incredible. Highly Recommend.
147282
147283
reason
12-25-2017, 10:54 PM
Interior Cleanup + Lizard Skin + Ceramic Coat
147284
147285
147287
Auto Twirler for the win - made cleaning up the roof sooo much easier
147286
147288
147290
147289
147291
reason
12-25-2017, 10:57 PM
Installing the Vintage Air FrontRunner
147292
147293
I love this shot of the VA frontrunner kit. Worth every penny.
147369
reason
12-25-2017, 11:00 PM
Time to mockup
147295
147296
147297
147298
This is the first time in a long time shes been on 4 wheels... :bananna2:
147299
reason
12-25-2017, 11:01 PM
A little before and after.:headbang:
147300
reason
12-25-2017, 11:07 PM
Mocking Up Radiator + Brakes + AC + Intake + Wiring
147301
147302
147303
147304
147305
147306
147307
reason
12-25-2017, 11:18 PM
Got access to a 3D scanner... figured may as well Scan the build in while i still had her taken apart- Should help a bit later down the road.
147308
147309
sandiegocamaro
12-26-2017, 12:00 AM
That 3D scanner is awesome! What are you plans for use? Custom interior panels?
reason
12-26-2017, 10:11 AM
Unfortunately don't get to get down to my shop too often with my day job- so the scan data gives me a super accurate virtual model of the car i can use to experiment with and model on when i can't get down there. Gives me a jumpstart when it comes to ordering components/material and helps me go into fabricating with a gameplan already in my head.
Right now havent done much with it other than plan out some underdash paneling to route wiring/fuse blocks and my trunk panels.... but will come in super handy when i get into phase 2 of the build.
reason
12-26-2017, 10:30 AM
Harness/Power Routing through firewall
Using a bulkhead to route battery to my starter
147330
147328
After routing the wire, was a bit concerned about potential rubbing/wear... and i like to make things pretty, so put a bit of nylon loom on the wire.
147331
After much debate- and many reccos across the forum, i picked up a Seals-it grommet to route the main harness through the firewall. Found a nice recessed area directly behind the the intake manifold and with some rivot nuts makes it super easy to remove and pass the ECU cables through.
147329
reason
12-26-2017, 10:38 AM
Underdash Dynamat + Wiring
So the car has a nice heavy coat of lizard skin and ceramic coat over everything...but i figured a nice layer of dynamat couldn't hurt. After much debate decided to go with the Dynamat Superlite.
147332
147333
Figured the speaker pods could use a bit of insulation as well... i want no rattles in this car.
147334
147335
147339
147341
reason
12-26-2017, 10:45 AM
ECU Mounting
After much debate, decided to mount the ECU behind the glove box under the dash. Going to be making a glovebox panel to mount my fuse block and OBDII port in the glovebox area, so had the space to spare. After some experimenting... noticed with a bit of trimming the factory bracket fit the dash curve perfectly. Cue my new favorite hardware Rivot Nuts and had a perfect ECU bracket.
147342
147348
Some additional shots in case anyone wants a better look - you'll also notice some studs i installed for the Vintage Air unit. Was getting too much movement with the Sheetmetal screws they provideded...this also allows me to remove and install the unit much easier while making sure she doesn't shift around at all when i get on it.
147343
147344
147345
147346
147347
DT69Cam
12-26-2017, 01:51 PM
Looks great! Which braided wire loom did you use ?? It looks to be a heavier gauge than what I used. Very nice.
reason
12-26-2017, 07:04 PM
Thanks - if your talking about the engine harness its a harness from http://www.wiringspecialties.com/ - For all wiring under dash and on the power cable it's actually just some PET Braided sleeving i picked up from amazon - http://a.co/8VrHnkf - Had a bunch of it laying around from when i did my entertainment system in my apartment- have split loom and expandable sleeving in a variety of sizes-
reason
12-26-2017, 07:18 PM
Center Console + AC Controls + Guages + Steering Column
Once i got the main wiring / Vintage Air wiring / ECU all figured out- moved onto the center Console. I'm going to be running Speedhut gauges in my main dash, but wanted to create a gauge cluster in my center console to monitor Oil, Water, Fuel.
Due to the slope of the dash- and partially for aesthetics - decided to create a recessed area where the AC controls used to be. I'll be replacing the Radio slot with my Vintage Air controls.
To be continued...
147359
147360
One last fun update - Been waiting forever on my iditit pro-lite steering column. Finally it arrived just in time for Christmas and was worth the wait. Absolutely amazing quality and weighs under 6lbs. Alas, forgot to order the adapter for the momo.. but shes in at least.
147371
147372
DT69Cam
12-27-2017, 01:38 PM
Thanks!
67SSDan
12-28-2017, 05:54 PM
Heck yeah man! You've gone off on this thing! I don't envy the process again, but you'll love it when you're done. I'm finally driving mine now after 11 years of screwing with it.
Dan
