View Full Version : 04 GTO Seats in 68 GM A body... How?
Sebambam
07-23-2017, 08:26 PM
Hi im looking for a writeup
For a proper Gto seat installation in a a-body.
Of course i saw a couple chevelle treads already but everybody has a different approach.
No show quality needed!
Proper driver installation is fine.
The rears need to be trimmed i heard, the front seats need brackets or can i reuse the oem gto brackets?
Help a dummie.. Lol
raustinss
07-24-2017, 01:38 AM
First yes the rears must be trimmed done ..peel of the leather and foam and go to town , separate the seats from the Styrofoam center section as well being as the width isn't correct either . For the fronts you either make your own brackets or yes you can modify and use the power seat base . The biggest complaints being the height so you need to modify to make everything as low as possible. My idea is to look at lowering the floor where the seat bolts to ...an inch isn't much on the floor pan but will be on the seating position.
Sebambam
07-24-2017, 05:16 AM
Thanks... Any picture guide.
I would rather like to not mess with my floors.
raustinss
07-24-2017, 05:22 AM
No not really ...youre going to have to do some digging I have seen pics where guys have cut the power seat bases ...maybe copy their ideas . Want to think "project overtime" and yes there might be a few but the one is a nova ....I think he was the guy who cut the bases where I got the idea from search project overtime nova maybe
Interceptor5588
07-24-2017, 05:46 AM
Use the OEM tracks if you want to keep the power seats. You will need to make a small bracket for each corner, mine are out of 1/8"x 1 1/4" flat stock, bent in a vise. LOTS of work but worth every minute. PM me your email for a few pics.
The rears, once cut apart as described above, fit better than you might think. It's fastening down the front of the base that's the hard part.
raustinss
07-24-2017, 08:24 AM
If possible find a gto donor and get the piece of the sheet metal the rear bases attach to . Then graft that to your floor ..I have the pice just haven't grafted it to the floor
Sebambam
07-24-2017, 09:05 AM
Thanks i will pm you
Sebambam
07-24-2017, 09:20 AM
So do you take out material off the rear seat bottom section?
How much off the rear top section? Do you cut the frame part and weld it back together? Or leave it "open"
csouth
07-24-2017, 10:36 AM
CHeck this guys photobucket. I bookmarked it a long time ago when I had GTO seats in my plans...
http://s975.photobucket.com/user/zxxv111/library/?sort=4&page=1
Sebambam
07-24-2017, 12:18 PM
Thanks .. thatts a nice writeup for the front seats..
I dont know about the rears..lol
raustinss
07-24-2017, 07:24 PM
Great write up ....including the gto floor graft piece
Interceptor5588
07-25-2017, 07:02 AM
I remember using many of his ideas, except that. Good idea if it's available.
Sebambam
07-25-2017, 08:43 AM
Yea i dont have the gto rear seat brackets available so i have to find a way
Sebambam
07-25-2017, 09:15 AM
My car is a bench seat model so i have two holes on the driver side and two on passenger.
So i have to drill new holes regardless and i dont mind.
Do you have a positioning template or did you just test fitted it.
As far as i understand there are two options to make the front seat rails fit. (rear 45* bracket)
1. Cut the 45 off and attach. Brackets as in pic
2. Build a 45 angel bracket and attach this to oem bracket.
Are you guys just shimming the floor part to make sure the seat is leveled?
Sebambam
07-25-2017, 09:36 AM
Btw. What seat belts you guys use?
csouth
07-25-2017, 10:29 AM
I think most people are using their stock belts. the rears would mount kind of funky and they are 3pt.
1989GTA
07-25-2017, 01:49 PM
Stock seat belts here. Front brackets are easy. The rear brackets take more fabrication. I have a 1965 Buick Skylark.
Sebambam
07-25-2017, 03:12 PM
Do you have pics of the rear install?
chuckd71
07-25-2017, 04:04 PM
Stock seat belts here but putting the GTO ones in at some point. I just used large circular welding ground magnets to hold the seat bottoms down, they aren't going anywhere. For the uppers, I put a rod across the hooks in the upper seat back where the original seats mounted, then just hung the gto uppers on it. My rear needs to tilt a bit to get the top up/down though so that might not work for a hard top.
1989GTA
07-25-2017, 07:43 PM
This is the only one I have and it is in the mock up stage. Flat stock was used for the front and welded to the seat rail. The rears were two piece with the top piece welded to the GTO seat rail and the bottom piece bolted to the floor with a slot for back and forth adjustment. Than a bolt through the back side to bolt the two pieces together. The object was to get the seat as low as possible so my head would not hit the headliner. That part worked out just fine as I have enough head room. I am 6' 1".
142645
Sebambam
07-25-2017, 09:25 PM
Good info here.. Rear seat mounting pics would be great
1989GTA
07-26-2017, 09:14 AM
I will see what I can do.
Sebambam
07-26-2017, 09:55 AM
1989GTA
07-26-2017, 01:10 PM
Here are a couple of pictures. The top piece is a piece of angle stock welded to the GTO seat rail. Bottom piece is flat stock with bar stock welded to it and the bar stock drilled and tapped to receive the bolt from the rear.
Sebambam
07-26-2017, 03:38 PM
Nice thanks alot
1989GTA
07-26-2017, 06:39 PM
With the bolt coming in from the rear it is very easy to remove the seat and reinstall it.
Sebambam
07-26-2017, 09:23 PM
Just wondering if that extra inch of height would hurt. While i could just weld a flat piece to the rails and get them a lil lower.
1989GTA
07-27-2017, 12:01 PM
I think the location of the bolts holes would be the problem. The bolt hole would be where the edge of the seat rail is. You could drill new holes. Did you state that you had a bench seat? If so the inside holes would have to be new anyways. You could put the bottom section of the seat in place and look things over.
Sebambam
07-27-2017, 01:44 PM
Yes in had a bench so new holes are required anyways
Sebambam
07-30-2017, 10:47 AM
Thanks for your support guys.
Thanks to you i was able to modify my rails, weldet on som sturdy brackets and mounted the passenger side already.
I leveled the seat mounting points with some plates i found at home depot.. I used construction adhesive to glue them on so i have a leveled base for the rear mounting points of the seats.
Sebambam
07-30-2017, 08:49 PM
I took the rear seat top part appart and was cutting at 5.5 inches meassured from the bottom, i cut a straight cut
Now it should sit at a reasonable height in my 68 GS
Did you guys reshaped the bottom section?
How did you stretch and reattached the leather on the trimmed bottom part? Spray glue? Upholstery clamps?
Regarding the frame,did you just straight cut it.. Or did you weld the frame bottom part back on?
Do you trim the "hump" for better fitment?
How did you mount the rear bottom and top section to the car?
I was thinking to maybe get some plywood and mount the top section on it then mount the whole piece to the car?!
Sebambam
08-01-2017, 08:24 PM
Today i trimmed the rear seat frame and weldet the bottom piece with the mounting "noses" back on
142865142866
