JLMounce
07-17-2017, 02:15 PM
My car is in desperate need of new subframe bushings and I'm about ready to purchase a set of solid bushings for it. My internal debate is on whether or not doing sub-frame connectors is something I should be doing or may not make that much of a difference.
I'll preface that starting off by stating that through the floor SFC's like Detroit Speeds aren't an option. I don't have the welding or body experience to do it right myself and the shops around my area that I trust to tackle such a job are typically booked 3 years out unless it's collision based stuff.
So that leaves with with the bolt on subframe connectors from places like Hotchkis, Global West, PTFB etc.
Currently my bird is still fairly stock. It has the following suspension changes
Hotchkis 3" drop leafs
Hotchkis 2" drop springs (BB rate for 455 Poncho)
Gabriel VST shocks
.5" tall ball joints
Modern alignment
17x8 front w/ 245/45/17 BFG Sport Comp II
17x9.5 rear w/ 275/40/17 BFG Sport Comp II
Everything else about the chassis and suspension is as it came from Pontiac in 1969. The car is used 98% as a street car and for that purpose it does pretty well. It may see a couple trips down the drag strip per season and because I don't have an upgraded oiling system, I don't do any cornering events with it for fear of ruining the engine. This is a goal within the next couple years however is to do a couple auto-x events during the summer.
Given the car's usage and setup, I am questioning the need for SFC's at all. Especially considering I'm looking at the bolt-in variety. I'm sure they won't hurt, but some of these parts are near or over $400.00 and I can better use that money elsewhere on the car.
Any advise here is appreciated. Also if you have a recommendation, that is appreciated as well. Thanks guys!
Gabriel VST shocks
Modern alignment
