View Full Version : 3 point harness intsallation 64-65 GM body help needed
therobski
07-14-2017, 01:54 PM
Nag it Mr. Administrator I posted this thread in the Interior Section-sorry. Guys I would to like install a 3 point harness in my 64 F-85 post car and these early GM A-body's (64-65) had no provisions in the B pillar or around where the coat hangers would be in the roof line. Any ideas, pictures would be great. Has always, thanks for the support in our Club.
morrisclassic
07-14-2017, 02:02 PM
Maybe not an option with the post already painted but...
Fabricators weld a nut on a plate and slide it up inside the post or
cut a rectangle out and weld a plate with a nut, flush with the inside .
Billy
therobski
07-14-2017, 02:56 PM
Yes sir never thought it through this far with the interior build. I saw those plates, and yes welding is not the best option. I wonder if I can surgically cut the hole in the pillar with a small Dremal cutoff wheel, use that high tech body panel glue and finish it with rivets? Still may not be strong enough? Don't know.
therobski
07-14-2017, 05:58 PM
I wonder if there's an application that may work that's for a convertible???
dontlifttoshift
07-15-2017, 04:17 AM
You don't have to weld it. If you can get the nut plate up there, once the seat belt is bolted to it, you're done.
therobski
07-15-2017, 04:47 AM
That's sounds reasonable, I wonder if tohers in this Club have done this and have some details and pictures.
