View Full Version : Questions about C6 brakes on my Cutlass
DewChugr
07-11-2017, 06:02 PM
I'm restoring my 71 Cutlass convertible and I have a set of C6 brakes for it. I have a 2000 camaro disk brake master cylinder and am planning to use the stock booster. I have brackets for the front and drum spindles and ls1 backing plates for the rear and a f-body parking brake cable. I am replacing all the lines with nicopp.
It had a 1/4" brake line running to the back. Can I use 3/16" for everything? I think that's what the Vette uses.
Can I use the stock distribution block?
i think I need a spacer between the axle and backing plates. Does anyone sell one?
dhutton
07-11-2017, 06:10 PM
Rear brake spacer here:
http://www.brphotrods.com/products/1st%20gen%20F%20products/index.html
Don
CapSS92
07-12-2017, 09:14 AM
I've done several cars with your same setup and used 3/16 all around. No problems with anything. Stops great every time. :)
DewChugr
07-12-2017, 09:54 AM
Thanks guys!
- - - Updated - - -
Do you run one line to the diff and split it or run two from the front?
dhutton
07-12-2017, 10:20 AM
One line to the diff and split it.
Don
DewChugr
07-12-2017, 10:24 AM
Great, thanks for the help.
CapSS92
07-12-2017, 11:51 AM
Ditto. Also ran two lines from the front into a junction and one line into the prop valve. Blocked off the second prop valve front output. Looks cleaner and works just fine.
