View Full Version : Power Steerinf for LSA
joeko23
07-08-2017, 10:34 AM
Hey guys,
Looking for a power steering pump for my LSA and Chassisworks rack and pinion. Their instructions state flow rate of 1-1.5gpm. Any ideas what pump I can use and brackets needed to bolt up to LSA? Also their output shaft is 16.8mm DD. Seems like they are the only ones that make u joints that size? Any suggestions greatly appreciated!
dhutton
07-08-2017, 05:30 PM
Turn-One has a pump that will bolt to the factory LSA accessory drive.
Don
nicks67camaro
07-09-2017, 04:03 AM
I think there is an add on kit as well. I think this is the route I'm taking. The part numbers are listed individually.
http://www.oemautopartsandaccessories.com/catalog/parts/view/n/p-s-pump-20806165/v/cadillac-cts-2015/vtec/416860/pid/fc731e3af5d4e5fd/
joeko23
07-09-2017, 04:48 AM
The problem is that I don't know the flow rate of the pumps. I know the L99 camaro pump will fit also and they are available pretty cheap. The problem is the flow rate. Anyone know the flow rate of the pumps??
dhutton
07-09-2017, 05:35 AM
Flow rate of stock pumps is too high. Over 2.0 as best I can recall.
Don
dhutton
07-09-2017, 05:38 AM
Flow rates here:
https://ls1tech.com/forums/conversions-hybrids/1262185-power-steering-pump-outputs-gto-f-body-corvette-cts-v-truck-etc.html
Don
joeko23
07-09-2017, 06:11 PM
I think I found what I was looking for in that thread:
2010+ Camaro
Flow: 0.9 to 1.3 GPM @ 400 RPM; 1.8 to 2.2 GPM @ 1500 RPM - Flow tested at about 100psi
That should put me pretty close in range and the LS3 is same block as LSA so I should be able to bolt up the stock camaro pump no problem.
Thanks!
Now if I can find 16.8mm ujounts that are less than $100 each
nicks67camaro
07-10-2017, 03:56 AM
Good to know. Looks that that pump and bracket combo is cheap!
http://www.wholesalegmpartsonline.com/products/Chevrolet/Camaro/PULLEY-Steering-Pump/2670108/12610794.html
Randy67
07-10-2017, 05:52 AM
Just a FYI, 2010-2012 Camaro V8s had hydraulic power steering, 2013-up V8 used electric steering.
Bugzilla
07-10-2017, 11:22 AM
Just throwing another option out there for you. I normally use a PS bracket off the older CTS-Vs (LS6 version / GM # 12578551). Then you can use an aftermarket pump from Sweet or Howe. They offer them in a wide variety of PSI and flow rates, most within your needs. The only downside is that you would have to run a remote reservoir.
