View Full Version : Procharger LS Transplant kit in 68 camaro with AC and Speedtech Subframe
72Z/28
07-04-2017, 08:31 PM
I have a 68 camaro equipped with LS6, Speedtech Subframe, Corvette accessories drive and AC compressor is mounted on the passenger side via bracket from Kwik Performance.
I am interested in installing a procharger kit and wondering if anyone has done this install a first gen with A/C mounted on top, passenger with Speedtech Subframe. I have looked up in google, unfortunatelly could not have any luck finding pics or at least or anybody did this install with a similar set up.
Will appreciate receiving some input on that.
Thanks!
IMPALAMAN1
07-06-2017, 09:41 PM
Where is your alternator? Do you have power steering? I am using the transplant kit.... but it puts the alt where you have your ac. If no ps you may be able to put the alt there with a custom bracket.
72Z/28
07-08-2017, 10:13 AM
Thanks for the reply. I am using the C5 corvette accessory drive where it puts the alternator on the driver side. Yes I do have power steering as well. The A/C compressor also mounted on passenger side, uppor side.
I have seen Vortech LS swap kit which puts the head unit on the passenger side. This means the A/C compressor has to be mounted at the bottom side.
Nitrous
03-12-2018, 12:57 PM
Was this ever done? I've been looking for some photos of it as well but haven't seen any besides a video on youtube but the hood was off and it looks like it could have questionable hood clearance
thedugan
02-26-2020, 06:16 AM
Old post but looking for similar info. Have a D1sc to add to an LS2 and need to figure out the bracket setup. Emailed Procharger but haven't heard back. Anybody know of a bracket system that works. Using basically same drive setup. If needed I would replace it all if a good system is out there.
IMPALAMAN1
03-13-2020, 02:41 PM
Contact Bob at brute speed. Website is good for finding brackets and parts. Good to deal with and gets back pretty quick.
