View Full Version : Ramliftpro
silverr1ride
06-29-2017, 06:01 AM
Has anyone used these?
https://www.ramliftpro.com/
Cool, I know some OEM's have systems of the same concept.
doesn't JRi sell shocks with the same setup?
silverr1ride
06-30-2017, 05:25 AM
JRI is 5k. These are 2500.00 that you add to your existing setup.
ShockWaves are $900/pair. http://www.ridetech.com/products/shockwaves/ A complete 4 wheel ShockWave system with an AirPod electronic compressor/leveling system would run around $3600.
There are pros and cons to both products. The hydraulic lift system is expensive, requires a hydraulic pump and lines, and takes up some room on the coilover that may reduce the amount of available travel. The ShockWave system also requires a compressor system to operate, but offers a wider range of ride height adjustability as well as ride quality control.
The hydraulic setup lets you change ride height, independently from spring rate
