View Full Version : Which kit to buy AAW or Painless
joeko23
06-21-2017, 05:41 PM
I bought a 69 Camaro shell, need to fully wire the car which kit should I buy the AAW or Painless, maybe you guys have other suggestions? Also why is there like $200 difference between the 2 kits? Is one more complete? Also I'm not that electrically savvy, but can follow instructions really well so it's important that the Manuel is detailed.
I will have an LSA, power windows, power door locks, power trunk release, sound system with 4 speakers and sub with amp and some Bluetooth head unit.
thanks
minendrews68
06-21-2017, 06:01 PM
I used EZ Wiring for my Camaro. I don't have any complaints and a heck of a lot cheaper.
Z06vet
06-21-2017, 06:53 PM
AAW update wiring kit. Perfect for what you described you're running.
sheck44
06-22-2017, 02:06 AM
AAW Update ...I ran AAW with the PSI LS harness and GM computer ... perfect
Steve
130fe
06-22-2017, 02:58 AM
Another vote for AAW, Classic update kit. Have one in my 68, great kit!
csouth
06-22-2017, 07:34 AM
Another for AAW... Even if you don't spring for the Classic Update, their builder series harnesses are great.
joeko23
06-22-2017, 08:55 AM
Thanks for your help. AAW it is. I checked out the ez wire but I think it will have too many things missing and I will spend same money in the end.
65 drop top
06-25-2017, 12:20 PM
chpr1972
06-25-2017, 06:49 PM
It sounds like you are going to use a lot of upgrades. I bought the AAW classic upgrade and was not happy with it. I have added relays and extra wires for my upper and lower headlights, twin relays for my fans, relay for my conv top, and electric fuel pump. That also includes a 100 amp fuse and 2 gauge wire to a separate connector for the relays. I will have another one if I ever get around to putting a amp system in it . My HP EFI has it's own wiring as well as my Vintage Air. I do not know if someone make a kit that has all these relays built in for all these accessories. I use the top terminals on the battery to run the car. I use the side terminal to run all the relays and accessories. As a note I took a Ford starter solenoid and gutted it and use the terminals for my power to the relays and the other side as grounds so every thing is grounded right back into the battery. Most of these accessories recommend you ground everything to the battery there by I used the solenoid.
H2Ogbodies
06-25-2017, 08:08 PM
It does depend on your options of choice. Even their update kits (or anyones for that matter) cant take everything into consideration. My auto upgrades go way beyond what they could offer hence why I build my own and for others but for example fan control-they give you a relay control...so what? How about I want to run a dual 14" F150 fan assembly but what if I want to convert it to a 3-speed setup using relays?
What if I plan to add 1-touch auto down and up windows?
What about a delay off lighting circuit?
Does the update kit cut-off the AC compressor on WOT?
It just isnt possible-oh but you can call and have them build a custom harness once they figure out if they can do it-remember if they dont have schematics to use it may take awhile to hear back. You dont get factory fit replacement harnesses like NOS with upgrades-that would be too costly for them-Im sure they assume as long as you have neat printed wiring and make you do all the terminations thats all you need.
65 drop top
06-25-2017, 11:22 PM
Although I voted for AAW because my Chevelle was recently wired with AAW and operates flawlessly, the guy who helped me wire the car prefers this http://coachcontrols.com/index.php?main_page=products_all . He wires a lot of high end car locally here in So Cal. I had already purchased the AAW kit before I met and hired him to help me. He said the AAW kit was nice and complete but did have to add several relays and modified the harness to eliminate some of the wires that weren't used. The Coach Controls unit has built in relays and a lot of modern features. I'm planning on using the Coach Controls unit in my current '55 Chevy build.
AAW is more complete, it includes many exclusive GM connectors that other kits require you to reuse old or use items completely different such as two or three spade connectors instead of a single plug
csouth
06-26-2017, 06:55 PM
thanks
The update kit will have an accessory circuit for your PW, PL, and you can use on of the others for the trunk release. Not sure how your LSA harness is made, lots of aftermarket harness have relays for Fans and Fuel pump. I used the fuel pump wire from AAW as a fused circuit because my LS harness has the fuel pump fuse. My audio system only uses the body harness for power to the radio.
Be sure if you choose other options, that you can get tech support. I know without a doubt you can from AAW because I've call on a few occasions.
I'm with Rod, if you're not in depth with wiring buy the Classic Update. A builder harness will have you making lots of connections yourself.
parsonsj
06-27-2017, 07:10 AM
For high end cars using lots of options and wishing for BCM-like capabilities, InfinityBox is the way to go.
http://infinitybox.com/
I've used their stuff many times. It requires wiring expertise, but most folks can manage it. Plus their tech support is amazing.
65 drop top
06-27-2017, 10:53 PM
Just curious, why do you say it requires wiring expertise? According to their website you don't need any experience at all.
dontlifttoshift
06-28-2017, 04:36 AM
You have to have a better understanding of 12 volt systems to use the Infinity Box vs Classic Update. The Infinity Box is built for all cars while the Classic Update is built for your model car. Again, given the OPs experience AAW Classic Update is the right answer, their print is second to none along with the packaging/grouping of different sections.
Regarding the Coach controls fuse box. Just like Infinity Box, you have to understand 12 volt systems when trying to integrate that into your car. My huge hang up with Coach is the printed circuit board carrying any amount of amperage. Centech does the same thing and I have replaced a handful of those over the years. I have recently learned that you can melt a fuse before it blows so no thanks on a PCB.
Infinity Box is stupid money for a base kit (in my opinion). For me, it just isn't that important that the lights come on and dim slowly, one touch windows, or any of that other gingerbread along those lines. Also, it drives me crazy that I can't change the I/Os myself.
I prefer to wire from scratch.....building my own fuse and relay centers, packaging them where they need to go, and using all black wire (aside from the EFI harness). For me it's easier........for some, they would end up in a rubber room.
Once again, no right answer for every situation.
parsonsj
06-28-2017, 12:55 PM
InfinityBox does say that no wiring experience is necessary, but Donny's right. You need to understand all the basics of 12v wiring to use their gear, plus you'll have to source all the required OEM connectors.
It is expensive, and they still haven't released the app so that us installer types can do our own programming. But I love it anyway, since all kinds of programming things are possible, and I really dig doing all the control circuits in 28g wire leaving the power circuits for the bulky 14g stuff.
MikeJ67
09-19-2017, 07:07 AM
What a great thread. I was just about to ask this question for my '67 Camaro. Apparently the prior owner thought you could "splice" the whole harness and it would be cool. Probably why my wipers don't work. LOL.
I think I'll check out the AAW harness since I don't have anything extra that I'm worried about. I just need a complete & new harness so I don't have to worry when the wife takes off in the car somewhere.
Thanks guys. Looks like I've got a solid Winter project ahead to look forward to. Too bad I don't have it "now" since the motor/trans is out of the car.
813Demon340
09-19-2017, 08:24 PM
Anybody use a Ron Francis wiring kit? I'm looking at their Mopar one.
badazz81z28
09-23-2017, 09:43 AM
After dealing with Painless.....AAW All the WAY!!!
I'm so disappointed in my Painless harness.
icemanrd19
09-23-2017, 01:57 PM
Aaw
kimosabi
09-23-2017, 06:41 PM
I have a 12 volt background and built alot of boat systems but I also know the time it takes to build a wiring harness so time constraints had me order the very specific classic update kit from AAW for my AC 70 Camaro sbc. Saved me alot of time because I could do all the other work needed while they built the harness and shipped it here.
PLUG N PLAY! I was actually impressed by the fit and ease of installation. Rip out the old, plug in the new. Took an afternoon to install.
all4sho
09-24-2017, 05:37 AM
i picked up a AAW update series for my chevelle, its not together yet but it looks good and layed out well
