View Full Version : 4.6L Terminator powered 1933 Ford 3 Window Coup $59,995.00
Snowcatter
06-15-2017, 07:51 PM
This is a truly one of a kind original steel body 1933 3 window Ford Coupe. Equipped with one of the coolest engines Ford ever produced - A Hand Built 4.6L Supercharged 32V pulled from a wrecked SVT (Terminator) 2004 Mustang Cobra. Engine and Transmission had 18,000 miles when wrecked and salvaged. Countless $ and custom fabrication were required to mate this engine with a 33 chassis. When this car is completed it will be one of the sweetest street rods ever built. (How many street rods with a six speed have you seen?) This car was a long time project I shared with my father who has passed away, and I simply don't have the cash flow he did to finish it without him. Most of the fabrication is complete. The car is very drivable as it sits, and all it needs is loose ends tied up, engine dyno tuned, Interior & Paint. (You get to pick the colors and finish how you like) Car has been driven in several hot summer parades and has never over-heated. Factory Security & Emissions have been removed from the ECM by Ron Francis. Front & Back Heidts independent suspension + a 6 speed T56 manual transmission make this car a real pleasure to drive. Please feel free to PM me with questions, and I'm happy to chat with serious buyers & anyone with questions about the 4.6 retrofit. I DO NOT need to sell this car, so please don't send me low ball offers or trades (unless you happen to have a salvaged 2013-15 ZL1 Camaro, or a 69 Camaro body shell for my next build ;))...Thanks for looking :) For a video search for Terminator Reincarnate on you tube.Some of the features of the car include:
- fully Boxed and reinforced original 33 Frame
- Chopped Top ( not sure how much was removed..I think 4")
- Custom built Stainless Headers, 2-1/2" Dual exhaust, side exit through body.
- Suicide Doors with remote keyfob actuation (I integrated the factory keyless entry from the donor car)
- Aluminum radiator with ECM controlled cooling fan, and custom overflow tank.
- Automatic Headlight/Dome light control by Dakota Digital.
- Provisions for Power Steering (The pump and reservoir is mounted, just need the power rack from Heidts)
- Power windows with billet switches, and trunk pop from key fob.
- Stainless brake lines, Wilwood polished rotors on four corners.
- Cobra Head shifter from donor car.
- Mounted chrome fire extinguisher, & Battery Disconnect.
- Polished Billet Battery Box, & Optima Battery.
- Fully Chromed Tilt Column, & Steering Wheel.
- ECM Controlled in tank returnless fuel pump.
- Vintage air compact heater box.
- Braided Stainless Lines on Motor.
- Aluminum Drive Shaft
Below is just some of the components and cost:
Heidts SuperRide IRS --
•IRS KIT WITH DRILLED ROTORS $7589.00
•Polished Housing $ 190.00
•Polished Uprights $ 345.00
•Polished Lower Control Arms $1400.00
•Chrome Half Shafts $ 685.00
-Ford 9" Third Member 4.30:1 $1500.00
◾$11,709.00
Heidts SuperRide IFS --
•33-34 Ford SuperRide Kit $3119.00
•Stainless Control Arm & Hardware $1015.00
•Polished Wilwood Brakes $ 480.00
•Stainless Spindles $ 365.00
•Polished Rotor Covers $ 580.00
•Billet Rack&Pinion $1018.00
•Chrome Stabilizer Bar $ 435.00
◾$7012.00
04 Modular 4.6 Terminator Eng/Trans/ECM $10,000.00
•Ron Francis Telorvek wiring Kit $ 870.00
•ECM Programming $ 360.00
•Polished Whipple Supercharger $ 5000.00
-Polished Valve Covers $ 650.00
◾$16880.00
Weld RodLite Wheels $ 600
Auto Headlight Control $ 199.00
Compact Heater Kit $ 250.00
AUTO METER Arctic White Gauges $ 700.00
Street Scoop Air Cleaner $ 275.00
33 Ford Chrome Grille $2500.00
Custom Built Aluminum Drive Shaft $ 800.00
Flaming River Chrome Steering Column /w Billet Chrome Wheel $ 750.00
14136514136914137014137114137214137314137414137514 13761413771413681413671413661413561413571413581413 59141360141361141362141363141364141378
