View Full Version : Difference between -6 and 3/8's fuel hose.
71LS5Formula
06-15-2017, 03:44 PM
I need some advice. What is the difference between -6 fuel injection line and 3/8 fuel injection line. Thank you.
sjaroslo
06-15-2017, 03:59 PM
My understanding of the AN sizing system is that the "dash" number is the number of 16ths of an inch, therefore, "-6" is 6/16" or better known as 3/8ths....
71LS5Formula
06-15-2017, 04:04 PM
So I should be able to use standard 3/8s fuel injection hose instead of the really expensive stuff.
TheJDMan
06-15-2017, 04:06 PM
AN plumbing is sized in 1/16th of an inch. So for example -4 is 4 1/16th or 1/4", -6 is 6 1/16th or 3/8", -8 is 8 1/16th or 1/2", etc. So size wise -6 and 3/8" are the same thing. How you connect that hose to your lines is a different subject. Don't try to install AN fittings on generic auto store fuel line.
CarlC
06-16-2017, 07:45 AM
AN is short for Army/Navy, a military specification used going back nearly 80 years to commonize on sizing.
For hose, the sizing is based on the bore size. Hence, as mentioned above, AN6 is 3/8" bore.
For hardlines, it's the O.D. So, the bore of the tube is based on the O.D. - 2X the wall thickness.
A really good read on this and fasteners is https://www.amazon.com/Fasteners-Plumbing-Handbook-Motorbooks-Workshop/dp/0879384069
