View Full Version : 70 camaro tubs
spencer
11-21-2005, 02:13 PM
Where can I find rear tubs for my 70 Camaro? Detroit Speed has them for first gen models, but not second gen.
jeffandre
11-21-2005, 02:31 PM
I added 4+" of sheetmetal to my stock tubs, overlapped the sheetmetal 'filler' onto the tub a bit and then welded them up completely. I also have an overlap between the loose tub and the tub part that is still on the car, that way I do not have to buttweld them, which will go a long ways towards easier fitting and welding.
The first pic shows 1 tub with the metal added. I only blasted the area that would get hot, no need to remove the relatively freshly applied undercoating. The second pic shows 1 finished tub ready to install next to 1 that did not have the metal added yet.
rickk
11-21-2005, 08:04 PM
jeff. i mini tub my camaro i got 3 in more room but hade to noch the frame rails by the tank i am running 18 12.5 fiske rims .if you have any questons giv me a call 214 908 2100 ,
thanks rick kirkindall
rickk
11-21-2005, 08:07 PM
jeff , my camaro is a 73 z28 rs cover car nov 04 phr .
rick kirkindall
Rocko71
11-21-2005, 09:37 PM
Not to try to hijack the thread, but Rick, do you have pictures of your car? i thought i remembered seeing it, but i was thinking you were running 17s at the time? also what tire size and backspacing are you using? thanks.
jeffandre
11-22-2005, 07:21 AM
I had to notch the heck out of my frame too, so I built a 'subframe' in the trunk and welded it in place for extra security since I still have leafs. I have 19x13's with 345/30/19's, backspcaing is 9.625". Leaves me 1" clearance between frame and wheel/tire, and the outside edge fo the wheel is 1.75" inside of the outer fender edge, so no rubbing issues expected.
Rocko71
11-22-2005, 08:02 AM
That sounds awesome, Jeff. Do you have any pics or a website? I went to your VB Garage thing, but there werent any pictures. Thanks,
--Rocky
jeffandre
11-22-2005, 03:03 PM
--Rocky
Try these links:
http://pg.photos.yahoo.com/ph/jaandre@sbcglobal.net/album?.dir=d1ea&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos
http://pg.photos.yahoo.com/ph/jaandre@sbcglobal.net/album?.dir=f0e6&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos
Rocko71
12-08-2005, 10:34 AM
Those are some great pics, Jeff. Nice work!!!
F70t/a
12-08-2005, 11:44 AM
You guy's have to see Jeff's car in person. The 19's look so damn sweet on his car. After seeing them on his camaro, I dont think I would ever do anything smaller. :hammer:
XTRMEASURES
12-08-2005, 12:45 PM
Try these links:
that is a seet car
you did a awesome job
jeffandre
12-09-2005, 02:26 PM
Thanks for the compliments guys. I wish I could get it done...Life keeps getting in the way! Trying to finish the fuel system this month. I need the ATS AFX spindles soon, fully knowing that the wait will be worth it. I expect the car to be drivable (not legal) next year.
