jwcarguy
05-20-2017, 04:32 PM
I have a Detroit Speed Engineering " DSE" #090204 600 series quick ratio steering gear box by Turn One Steering Systems available
Bought for use on a buddy's pro-touring car (68' Camaro), but he has had unexpected things come up and unable to use it now
It is the 12.7:1 ratio new steering box, not a rebuilt unit, finished black housing
Fits GM cars 1964- 1992 (please verify)
1967 - 1992 Camaro Z28 SS / Firebird
1964 - 1977 Chevelle / GTO / Skylark / Malibu / Cutlass / Lemans
1968 - 1974 Nova / Apollo / Ventura
1978 - 1988 " G- body "
Desc. from DSE site:
https://www.detroitspeed.com/Steering/090204-600-steering-gear.html
600 Steering Gear
Now you can achieve rack and pinion steering performance with a bolt-in steering gear. This steering gear can be used to replace the common GM 800 series power steering gear used from 1964 to 1992. The 600 steering gear is available with a 12.7:1 or 10:1 ratio.
Its features include:
� All new steering gear unit, not rebuilt
� Increased steering feel due to low friction gear design Precision rack and pinion valve technology
� Late model performance car feel
� Quick ratio 12.7:1 or new 10:1 ratio
� 6 lbs lighter than stock
� Original power pitman arm may be used
� A new 3/4 x 30 spline rag joint is available through DSE
� New o-ring power steering hoses are needed
� 600 Steering Gear Outlet Fittings not included
NOTE: DSE P/N: 090214 has return and pressure line fittings included.
NOTE: For the 1978-88 G-Body and the 1982-1992 Camaro applications, a steering shaft kit will be needed. (DSE P/N: 092519).
NOTE: For the 1982-92 Camaro/Firebird application, modification to the steering gear housing will be required.
This is for the steering gear box itself, no hoses, fittings, pitman arm or rag joint are included
sealed instruction manual, DSE stickers included
SOLD!!
call/ text (702)677-4085
600 Steering Gear
SOLD!!
