battenheaded67cutlass
05-16-2017, 08:10 PM
Hello All, this is my first thread, and I am only posting after reading a ton on here to learn all I can, but I have come to a fork in the road....
Trying to decide which way to go on the suspension setup..... This is going to be a shared car between my 70 year old Retired and disabled Dad and myself.... it has been a long project coming, and finally getting some "traction". I plan on street driving it in the mountains ( I live on the west side of Denver), taking it to cruises, and maybe down the dragstrip a few times if it runs really well.... Altitude really knocks the beans out of the Horsepower!
We really have no plans currently to do anything buy maybe try autocross, and that isn't for sure, because we are on a pretty tight budget and probably won't buy but one set of tires.... So I have to make them count when I buy them!
Specs on the car:
1967 Olds Cutlass 2 dr hdtp.
455 Oldsmobile - Motec M4 Fuel Injected engine built by Joe Mondello with Hydraulic roller cam (235 @ .050 on both) and fully ported Iron Batten Heads -9.5:1 comp. I think it will hit ~525 hp
American Racing headers 1 7/8 primaries and 3 inch merge collector - Thanks to these guys, they welded on my custom Batten port flanges
Built TH400 with 2800 stall TCI converter
3.73 12 bolt chevelle rear differential -no c clips Mark Williams axles, Eaton Truetrac, 3.73 Motive perf gears, moser 7900FM housing ends
ZL1 camaro Rotors front and rear, CTS-V 6 piston/4 piston calipers - LSX concepts caliper adapter brackets on the front and FLYNBYE rear caliper adapters
Probably use Corvette 18 inch wheels and billet spacers to get clearance past the big brakes..... but these haven't been purchased yet... really want 18's instead of 19's or 20's... Wanting to do 295/45R18's on the rear....
on the rear, adjustable upper control arms and fully boxed lower arms, with poly bushings on one end and the spherical delrin joints on the other ends
So, for the front suspension, here is what I have already or plan on doing:
I am looking at BMR 2 inch drop rears and 1 inch drop front springs(only one inch drop in the front because the 1/2 taller lower ball joints drop the height .5 inch, and the 700lb engine will drop it another 1/3 to 1/2 according to BMR)
planning on Tall lower ball joints
looking at Stock lower control arms with poly bushings installed (does someone make greasable ones?)
have 1.25 front sway bar with poly bushings
1 inch rear sway bar bolt on
Stock A body disc brake spindles
HERE ARE THE OPTIONS I AM LOOKING AT:
option 1- Stock Upper and Lower control arms with Poly bushings installed and tall lower ball joints only , All 4 Bilstein HPS 1000 Shocks or QA1 non-adjustable shocks
option 2 - Stock upper and lower Control Arms with Poly bushings and tall lower ball joint, with QA1 single adjustable shocks all around
option 3 - SPC adjustable upper control arms with extra tall ball joint and Stock lower Control arms with Poly bushings and tall lower ball joint, with Bilstein HPS 1000 shocks or QA1 non-adjustables - there isn't money for both SPC's and adjustable shocks.
The question is, with the suspension being tight and rebuilt on poly bushings, with big 18 inch tires, and being lowered, will a novice, non-road racer like myself really notice a substantial difference in using the SPC upper control arms?
I am wondering if option 2 would be the best overall for us with those BMR lowering springs... with the single adjustable shocks, will these make the most difference?
Also, I have never ran lowering springs on stock control arms, will the alignment be tough to do?
We only have so much to spend on what is left on the car, and although I would love to do the SPC arms and adjustable shocks, we just don't have the budget.... same for forged 18 inch wheels.... thus the reason for the corvette replica wheels
Specs on the car:
