View Full Version : Press in studs?
Cshenker1121
05-16-2017, 05:53 AM
I had some Arp 1/2" studs pressed into my rear axles and front hubs, and almost all have a small space between them, just about where i can almost slide a razor blade behind them. i tried to re-tighten all of them and they seem to be bottomed out where they cant go any further? is this an issue? will they seat when i start to drive the truck and re-torque the wheels? the truck is not running or driving yet so this is not urgent, id just like to figure it out.
Thank you.
Apogee
05-17-2017, 02:07 PM
Hmm...were the holes resized for the proper .005"-.008" interference fit? You definitely want the heads seated firmly against the inboard face of the hub and/or axle flange, otherwise they can and will loosen during use, and a loose stud is often a broken stud in short order. If you paid someone to press them in, I would be talking to them first since that's not right IMO.
astroracer
05-18-2017, 02:30 AM
Knock one out and check the hole for a chamfer to match the radius on the underside of the head. If the holes were re-drilled adding the chamfer may have to be done to get the bolt to seat correctly.
Mark
65 drop top
05-18-2017, 09:15 PM
Mark
This was my first thought too
andrewb70
05-19-2017, 05:50 AM
Mine too...
Protour_Pinto
05-19-2017, 08:55 AM
Cshenker1121
05-26-2017, 08:51 PM
i ended up going over the rear studs with tons of washers and anti seize and a 1/2" impact. they are all seated well now from what i can see, just took some time. the fronts i am going to go over again with the hydraulic press. thanks guys!!
nokones
05-27-2017, 04:56 AM
After you first drive the car, recheck the torque. You should do that a couple times a day for several days just to be on the safe side. If you autocross, you should do it after every run for a few events.
chpr1972
06-06-2017, 10:22 AM
I had that problem with moroso studs and aftermarket axles. I had to take it down to a machine shop and have them pressed in.
