View Full Version : 1971 protouring rs camaro
SPEEDSTREAM69
05-14-2017, 06:27 AM
BODY
· Original Texas Rust Free Car
· Retains all original metal
· Body off restoration done
· Media blasting of all components including body
· All sprayed in high zinc epoxy primer
· Paint Porsche Artic Silver with custom carbon fiber stripes detailed with red pin stripe, all high end materials Glasurit paint and clear coat
· All new bushings throughout (body ,leafs, control arm, rad support)
· All new ball joints
· New steering arms
· New rag joint
· New brake lines
· Griffen aluminum rad
· Flexalite twin electric fans
MOTOR (Brand New)
· All aluminum LS2 with LS9 cam upgrade
· Magna charger TVS 1900 supercharger
· Katech front mount heat exchanger
· Fast 65lb fuel injectors
· 92mm billet throttle body
· BRP custom conversion motor mounts
TRANNY
· TS6 six speed with LS7 clutch
· BRP custom conversion tranny cross member with mount
FUEL SYSTEM
· Aeromotive stealth 340 intank with custom baffle system, inline filter regulator, braided line with an fittings front to back
REAR END
· Currie powder coated Ford 9” with big bearing torino bearing ends
· 370 gear with nodular center section
RIMS – TIRES
· Asanti / Fesler 19” 3pc rims
· 305 30 19 Hankook V12 rear
· 255 35 19 Hankook V12 front
BRAKES
· Dual diaphragm booster
· Wildwood adjustable proportional valve
C6 Z06 front 14” rotor 6 piston caliper
C6 Z06 rear 13 ½” rotor 4 piston caliper with drum in hat E brake
· Kore 3 rear ford 9” brackets
· Lokar ebrake cables
· Kore 3 hubs with GM tall sprindle brackets
· Up graded ½ 20 wheel studs
EXHAUST
· BRP ceramic coated mid length headers, 3” stainless steel exhaust with tail pipes
SUSPENSION – STEERING
· Trans AM quick ratio steering box
· QAI front adjustable coilovers
· DSE 3” drop rear leafs
· CAL TRAC (Traction Bar)
· Gen 2 frame connectors
GAUGES
· Autometer phantom II
· AEM wide band air fuel
· Carbon fibre gauge bezel
MISC
· Howell EFI computer and harness ( motor & tranny)
· American autowire (complete kit)
· Fat mat insulator
· New carpet and interior panel kit
· Recaro interior
· Custom wrapped dash
· Custom wrapped console
· LED headlights
· Custom bumpers front and rear (buttons removed , fang added to rear, chrome stripped and painted body color)
· Trunk mount battery
· Lokar throttle cable
Located in Toronto Ontario
PLEASE NOTE CAR HAS ZERO MILES!
really nice car
Pictures will be sent to Seriuos buyers only
NOT A FIRE SALE
