View Full Version : What are these holes in the firewall for?
67RSSS502
11-21-2005, 07:49 AM
I am wrapping up all my connections and fittings over the next couple of weeks and have come across 3 holes in the firewall that I am not sure what to do with. I have indicated which hole I am unsure of and have looked in my assembly manual and can't seem to find them anyplace. If anyone can identify them for me it would be great.
Thanks!
Dion
67RSSSS502
Happyfunballs
11-21-2005, 09:09 AM
Pic one looks like the factory clutch actuator hole and the e-brake cable hole. Pic two looks like the factory accelerator pedal hole. I'm just going off of memory....which isn't that good. Do you have these items routed in the correct holes? If so, don't know what they're for.
Jim Nilsen
11-21-2005, 09:59 AM
Pic 1 is the clutch boot hole for the rod to go through and the speedo cable hole. Pic 2 looks like a hole that was put in for gauges that were an after thought but I am really not 100% sure about that one,haven't looked at a stock 69 for a long time.
Jim Nilsen
smittys69
11-22-2005, 01:07 PM
Hole #1 - same as Jim said. Hole #2 - picture pretty dark but maybe for gas pedal linkage? If that's not it, it doesn't belong there
Steve68
11-23-2005, 05:51 AM
Way to dark, gas pedal linkage hole should be behind the valve cover, over farther
