Try2paz
05-01-2017, 07:24 PM
Item Location (City/State): Livermore, CA
Price: 55k
Description: 1966 Fastback
https://mikemaierinc.com/2017/01/nates-1965-ford-mustang-gt350/
351 windsor (Blown Head Gasket or Needs a new set of rings) Either I sell it now or put a motor back in it and sell it more more later.
Motor made 350RWHP at 5500 RPM. Pro System Carb, Full MSD, AccuSump, Sea Tab Oil Cooler. I had a fuel pickup issue last week and car went full lean. Car runs but has coolant in oil.
4 speed toploader transmission / Mark Williams Drive Shaft "Chromoly" with 1350 Yokes
9” rear end with detroit locker
C&R radiator
Fuel Safe 20Gal Cell
MMI quick ratio power steering system with KRC pump
MMI Front MOD 1 coil over system with single adjustable JRi shocks (500 / 650 spring setups)
MOD 1 lower control arm assembly
MMI MOD 1 rear suspension kit
MMI 200 lb leaf springs
Bilstein shocks
MMI panhard rod system
MMI 1/2″ sway bar
Custom fitted interior
Woodward steering column
Momo suede steering wheel
Sparco seats / 6 pt Schroth Belts
Rear seat delete
Racepak IQ3 dash/data logger
Wilwood brake system
6 piston Superlite6 front brake kit with Thermlock pistons & 12.88″ rotors
4 piston Superlite4 rear brake kit with Thermlock pistons & 12.88″ rotors
1″ master cylinder
Stainless steel brake lines
Budnik 18×8 wheels wrapped in 225/45/18 tires
Complete Re-wire of entire car with coach works.
This car was built over the past two years and I've got receipts for everything I've got over 100k into the build not including the motor.
MMI, Inc put the car together and knows everything about it outside of the motor.
I ran last weekend at Thunderhill and was passing new Z06's in this beast. I hate to see it go but with the motor letting go and having my second kid life's priorities have changed.
https://static1.pt-content.com/images/pt/2017/05/NCSC1668_zpsut5c7vrp-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/NCSC1668_zpsut5c7vrp.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/66D69474A2B941A4A2F7B00C3AE5AC1B_zpsl0i1-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/66D69474-A2B9-41A4-A2F7-B00C3AE5AC1B_zpsl0i1tu09.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/NCSC3452_zpsylubtdxg-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/NCSC3452_zpsylubtdxg.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/B478522E7777449F8E79729CEFA872A9_zpse1j0-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/B478522E-7777-449F-8E79-729CEFA872A9_zpse1j0d4mz.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/47833A1706974524BA8ABF214E087E19_zpsmjbx-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/47833A17-0697-4524-BA8A-BF214E087E19_zpsmjbxvwoh.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/8F29FD72E3364724AA7C6677C47C879D_zpsmcgg-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/8F29FD72-E336-4724-AA7C-6677C47C879D_zpsmcggaj7n.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/17DEA61B79AB4D08820E315236FF5BE9_zpsxrlt-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/17DEA61B-79AB-4D08-820E-315236FF5BE9_zpsxrltatrm.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/B1331B240A4A473AB316508DAAE3FA0E_zpswhfa-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/B1331B24-0A4A-473A-B316-508DAAE3FA0E_zpswhfajkiq.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/AF3D51F9943741E1AE9A537CE8A7643D_zpsla3w-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/AF3D51F9-9437-41E1-AE9A-537CE8A7643D_zpsla3wqnua.jpg.html)
- - - Updated - - -
I grabbed a couple quick pictures tonight in the garage. I'll get the car out in the Sun this weekend and take some pictures.
https://static1.pt-content.com/images/pt/2017/05/EDD77421CF3140A7951E6C20F3710A94_zps7k6y-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/EDD77421-CF31-40A7-951E-6C20F3710A94_zps7k6yb3j2.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/A21B2507D152487D9EE0C4CAA0019E03_zpsimis-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/A21B2507-D152-487D-9EE0-C4CAA0019E03_zpsimisuoki.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/8EA40F732C3E4B2AA03DD23FCB1BE39B_zpsbo92-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/8EA40F73-2C3E-4B2A-A03D-D23FCB1BE39B_zpsbo92zdp7.jpg.html)
I've got a very nice PS setup, It's KRC Pump, Nascar Remote Canister with internal baffling, and a inline lower radiator hose cooler. I've got close to 4k In the PS setup.
C&R Radiator (Dual Fans)
https://static1.pt-content.com/images/pt/2017/05/8CA4095534554520865D4005F4DB78E8_zps6q01-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/8CA40955-3455-4520-865D-4005F4DB78E8_zps6q01dtgg.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/736233A5A6054257A07E6BBD527CBF27_zpsp7pa-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/736233A5-A605-4257-A07E-6BBD527CBF27_zpsp7pah4wo.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/8C82BF80330243DF9337A3019E8412D7_zpscvak-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/8C82BF80-3302-43DF-9337-A3019E8412D7_zpscvakresn.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/79BC5720994B49D986699FB966705B05_zpsrmfd-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/79BC5720-994B-49D9-8669-9FB966705B05_zpsrmfd3gnr.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/684222E6E7C34273A98EFEC3D9F92CE2_zpsuf6q-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/684222E6-E7C3-4273-A98E-FEC3D9F92CE2_zpsuf6qezev.jpg.html)
I had this "Control area" put together so you could still operate the car belted in. It's got Fire Pull, ignition, start, and turn signals and horn
All the carpet is brand news, door panels are band new as well
https://static1.pt-content.com/images/pt/2017/05/8AAC6E31BBBA4E91A85E52B8143C1600_zpsluhp-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/8AAC6E31-BBBA-4E91-A85E-52B8143C1600_zpsluhphvn5.jpg.html)
https://static1.pt-content.com/images/pt/2017/05/EBCAA229D17645DFABB8EC913465EEE8_zps2fzy-1.jpg (http://s1307.photobucket.com/user/Lightning2k/media/EBCAA229-D176-45DF-ABB8-EC913465EEE8_zps2fzy9rxx.jpg.html)
Price: 55k
C&R radiator
Bilstein shocks
MMI 1/2″ sway bar
Rear seat delete
1″ master cylinder
- - - Updated - - -
