View Full Version : RideTech TruTurn Alignment
67rally
04-27-2017, 02:54 AM
I PM'd RideTech yesterday, but have not heard back yet, and I'm bringing my '67 Camaro in for an alignment today. LQ9 engine, 245/40/18 and 275/40/18, Guldstrand mod, front sway bar, big brakes, Ridetech TruTurn/4 Link. Would like to run a bigger front tire soon.
The Alignment specs on the website are pretty broad...
Camber -.5 to -1.5
Caster +4 to +7
Toe -1/8 to -1/4
I want the car to handle really well at the track (the reason I upgraded from the Hotchkis TVS system this fall), but I still need it to cruise well...What numbers should I have them shoot for? I was going to go in the middle and say Camber -1, Caster +5.5/+6 and Toe -3/16. Is this reasonable, or should I be more aggressive and aim for the higher numbers? Thanks in advance.
Josh@Ridetech
04-27-2017, 04:57 AM
It all depends on how race oriented you want the car to be. If you're wanting to drive the car on the street and track, the numbers that I typically give for a happy medium are:
Camber: -.5 to -1
Caster: 3* to 5* (can be made more aggressive for the track if needed)
Toe: 1/16" to 1/8" toe in
The biggest factor in setting your alignment is preference. If you want a track car, aim for the aggressive numbers. However, it will effect the street manners/tire wear.
