View Full Version : 67 Camaro twin Turbo
crazy71chevelle
04-25-2017, 02:55 AM
Walk Around Video: https://youtu.be/TSp6n2WcO3U
1967 Chevrolet Camaro Custom
Twin Turbo Monster
400 Engine Dart Block Specifications URE Race Engines (Chris Uratchko) Aprox 900RWHP with a Mild TuneTwin Garret 64mm Ball Bearing Precision Turbos Water Cooled Custom Air to Air intercooler Custom Alum radiator
Oz Cheek Swept Manifolds 400 Cubic Inches Dart Block AFR 235 HeadsHand Ported Dr J's Stainless Valves 2.0501.600 Beehive Peterson Spring Comp Steel rockers4340 American Louisville Crank Howards Brand Ground by Callies 6.0 H Beam
Howards Diamond Pistons with latest Ring PackageCadillac Hyd Racing Lifters
Comp Cams Hyd
Small Idles 700 rpm
Titan Oil Pump
Cloyes true Roller Chain Mickey Williams Custom Aluminum Pan Kick out etc Big Stuff 3 Fuel InjectionATI Balancer CV MSD Crank Trigger MSD Coil MSD Dist ARP Fasteners Dynoed on Engine Dyno.not a Cassis dyno.Original Kentucky Car Rust free Quarter Panels replaced Stripped and PPG Base Coat/ClearSystem Factory Cowl hood Real 67 Camaro Bumpers Stripped & Plated Custom reworked rear stock spoiler / Lowered and rolled back New HID Headlights Fesler Billet Digital Tail Lights Fesler Billet Front Hood Hinges Fesler Billet Rear deck Lid Hinges Complete Late Model GTO Interior Billet Specialties Steering Wheel(Custom for this car)
Ididit Modified Tilt Steering Column
Classic Instruments Dash Flush Mount front and Back WindowsFactory tinted Smoked Side Glass American Auto Wire Harness with updated Fuse Panel Racing Fuel Safe Fuel Cell with A1000 Pump in Tank Custom Flat trunk Floor hidden Fuel Cell Earls Teflon Hoses (No gas Smell) Chris Alston's Chassisworks G-link Suspension w/ double adjustable coil oversCustom Stainless Steel Exhaust Tail Pipes in correct LocationInnovate o2 Sensors and AFR Gauge Detroit Speed Variable wipers Boost GaugeKenwood marine IPOD radio with remote and hiddenChassis ATS (American Touring Specialties)
Aluminum Corvette c5 Spindles
SPC Brand upper and Lower adjustable Control arms Eaton Springs Vari Shocks Mounted inside A Arm/Double Adjustable Narrowed DTS Dana 60 with Torque Arm Mount Strange SS Axles Tru Torque Positraction Coil Overs on ALL 4 CornersRancho Single Adjustable Gas Shocks Relocated Shocks Inboard Detroit Speed Mini Tubs Detroit Speed Frame Connectors Blue Printed Stock Frame Welded complete/Sandblasted DP 90 Primer Reworked K memberPan Clearance and Lowered engine Brakes Wilwood 1' Bore Master Cyl 14" Wilwood Rotors all four corners 6 piston Wilwood Powder Coated Calipers Front 4 Piston Wilwood Powder Calipers Rear Forgeline 3 piece Polished and Powder coated 18x11 rear 18x9 Front Tires: Nitto Nto5R Rear (Drag Radial) NittoNT05 4L80ETSI Racing Transmissions Chicago Illinois Northstar Sprag etc etc Heavily Modified Standalone Bauman Controller Torque Convertor with TCS All Billet Lock up Convertor
for more details call me at George 646-423-0707
139716139717139718139719139720139721139722
100s of pictures are available here : http://www.webeautos.com/detail-1967-chevrolet-camaro-twin_turbo-used-16248236.html
crazy71chevelle
04-25-2017, 02:57 AM
I really don't use forums often so I apologize in advance if I didn't setup Ad correctly.
the car is currently on Ebay located here : http://www.ebay.com/itm/1967-Chevrolet-Camaro-SS-Twin-Turbo-/132165663007
-George
646-423-0707
