robby8388
04-21-2017, 06:13 AM
I'm looking for a little advice from someone who is more knowledgeable than I am.
I bought a vehicle (68 Camaro) with a LS1 already installed in it and it ran perfectly fine. I decided to go bigger and swapped in a LS3. I still have the existing in tank pump, regulator, and lines. I can't get the engine to turn over unless I put a tiny bit of gas in the intake. Once I do that it'll start and stay running. It's a little choppy like it's getting starved until I push on the accelerator a little and it sounds healthy. I'm assuming it isn't getting enough fuel and the initial no start is the only thing throwing me off. I'm ruling out injectors because it runs once it fires and then will run normal once I push the accelerator. This leads me to the fuel pump. I'm assuming it's not big enough to power the LS3 vs the LS1 I pulled out. I don't know what pump is in it or what regulator. I'm trying to pinpoint the problem before I drop the tank and switch the pump out. Any suggestions? Would it be wise to buy a fuel pressure gauge to check before I drop the whole tank? Thanks!!
